B10 Hub Nylon Plugs-Where To Find And Are They Necessary?
4 replies to this topic
#1 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted October 27, 2014 - 06:45 AM
My hub and diffy gears got all mangled this summer and I notice no nylon plugs/screws in the hub...could that have contributed? Where can I get those plugs?
#2 boyscout862 OFFLINE
  • 13,431 Thanks
  • 9,380 posts
Posted October 27, 2014 - 09:47 AM
Take a pic of where you are talking about and post it. I'm in the middle of putting my son's B10 together and am willing to learn or help. Good Luck, Rick
#3 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted October 27, 2014 - 10:39 AM
B10 hub diagram showing nylon bushings
Album: B10
1 images
0 comments
#4 classic ONLINE
classic
  • 5,572 Thanks
  • 2,324 posts
Posted October 28, 2014 - 09:51 PM
The bolts that force the nylon plugs against the axle are supposed to be torqued down to 20 ft. Lbs. If I remember correctly. If you tighten them more than that, you will lose the differential action of the rear when making turns. If you just had bolts torqued down to the axle without the nylon plugs, you may have stressed the differential gear cluster, causing a gear to snap and getting caught up in the other cluster gears. I've heard of people making plugs from nylon cutting boards from the kitchen.
Edited by classic, October 28, 2014 - 09:52 PM.
  • MH81 and trowel have said thanks
#5 1031d OFFLINE
1031d
  • 32 Thanks
  • 90 posts
Posted November 06, 2014 - 08:08 PM
I sent you a PM about differential parts. If you need the hub too with the plugs I'll throw that in. Guys I'm parting out a 2012 rear end that has a broken axle tube if anybody needs anything cheap or wants what's left.
