140 Question
5 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted October 26, 2014 - 09:19 PM
I have a h3 140 and was thinking of making a weed whip with a hydraulic motor and a hydraulic swing. Question is is there a continues flow out of one of the other 2 hydraulic out lets to run the hydro motor and if so will it have the speed to actually cut weeds?
Plan it to use a disk with sickle sections for the whip if it will work
#2 Trav1s ONLINE
Trav1s
  • 3,582 Thanks
  • 4,558 posts
Posted October 27, 2014 - 09:38 AM
None that I am aware of but I would guess there could be a way to make it work.  I don't know what flow the pump is capable of sustaining either.  What year is it?  There were two different pumps used.  30000 and below uses the old style.  30001 & up uses the later style which essentially was used all the way thru the 300 series machines like the 318/322/330/332.
Edited by Trav1s, October 27, 2014 - 09:41 AM.
#3 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted October 27, 2014 - 03:58 PM
It's a 69
#4 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted October 27, 2014 - 04:46 PM
Not enough volume from hydro charge pumps to power a whacker, unless you used an awfully tiny hydraulic motor, and then it would likely lack power as well.
#5 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted October 28, 2014 - 05:12 PM
Shoot lol guess I'll have to come up with a new idea
#6 darmahsd OFFLINE
darmahsd
  • 2 Thanks
  • 7 posts
Posted January 02, 2015 - 01:04 PM
Run an auxiliary pump off the PTO like you would have to if
using a FEL.Lots of 140's use a FEL and the tractor's pump
doesn't have the power for that either.
