Cub 2146 Engine Surge And Backfire
11 replies to this topic
#1 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 26, 2014 - 05:22 PM
I got a free 2146 and the engine surges a bit and as it warmed up it got a bit of a backfire. This is why the previous owner got rid of it. It only has 286 hours on it. Cranked it this morning for the first time in seven years. Does anyone have experience with the Lindamere 349 engine? Where should it start looking?
#2 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 26, 2014 - 07:47 PM
Maybe I should clarify it is a Linamar 14 hp. Formally Onan.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted October 26, 2014 - 08:08 PM
I know nothing about a Linamar.  Heard good things about them, but never have I seen one.
Is the backfire only at high RPM or low RPM or both?  Does it go away if you choke it?
Ben W.
  • Jkrogers said thank you
#4 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 26, 2014 - 08:29 PM
The governor was floating up and down as soon as it started. It smoothes out when rpms are increased. After it warmed up a bit you could here it to begin to backfire lightly I think maybe through the carb. I have read that some had anti backfire devices installed but this one does not. I think I clean the carb.
#5 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted October 26, 2014 - 08:37 PM
Sounds like air is finding it's way in someweres.
#6 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Adding choke does not help.
#7 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted October 26, 2014 - 08:53 PM
I would imagine choking made it worse, try spaing soapy water just around the carb gasket and intake manifold gasket looking for bubbles while engine is idling, if one is suspected then cover it with a layer of grease and see if it changes.
Water in gas could also cause backfiring, drain old gas and refill with good high octane gas.
#8 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 26, 2014 - 09:29 PM
I had thought about adding octane. Also thought about maybe the fuel pump is weak and fuel supply is not steady. I will try the soapy water. Good news is that it does run.
#9 KennyP ONLINE
  • 38,261 Thanks
  • 45,876 posts
Posted October 27, 2014 - 04:50 AM
Not sure about these newer 'Onan's', but one of mine had a little backfire going on. Adjustments did nothing. Pulled the breather and was watching it start and saw gas coming back up the carb. Come to find out, the exhaust valves were out of adjustment (too loose) and not letting the gasses out, so they came back up. Starts and runs great now.
  • Alc and Jkrogers have said thanks
#10 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 27, 2014 - 08:32 AM
OK, I can add to that my list of things to check out.  Next time I start it I will try to take a video of it running and get that posted.  That might help get the problem solved.  If others have ideas, I am all ears.  Thanks!
#11 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 27, 2014 - 07:17 PM
Does anyone have a service manual for a Linamar Zx390 14 hp engine that goes in a Cub Cadet 2146? Specifications? Thanks!
#12 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 29, 2014 - 12:08 PM
I set the valves to the correct clearance cranked it up and no difference. Still loping and backfire through the carburetor. Any suggestions? Thanks in advance.
