129 Starter Generator Belt Tension
5 replies to this topic
#1 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 25, 2014 - 10:01 AM
I am restoring a 129. I purchased a new belt for the starter generator (3/8 x 32") and I have to roll it on over the basket and generator pulleys. There is no slack, the generator is up against the block. This just does not seem right? Am I wrong? I have thought about getting a bit longer belt. Help
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 25, 2014 - 12:10 PM
Sounds like the wrong belt to me,gonna be real hard on the bearings I would think.
  • Bill 76 said thank you
#3 EricFromPa OFFLINE
EricFromPa
  • 3,523 Thanks
  • 3,070 posts
Posted October 25, 2014 - 01:17 PM
Cub manual says 3/8" x 31"
What size pulley is on the Starter Generator?
Someone may have put the wrong tensioner bracket on it.Had that happen on a Case 210.I ordered a stock size belt and in this case it was to Big.Someone put a shorter tensioner bracket on it.
Here's a pic of my 129 for reference.I need to get a new belt for it to very soon.you can see it's Almost out of room on the adjuster.
  • Jkrogers said thank you
#4 Bolens 1000 OFFLINE
  • 14,903 Thanks
  • 18,103 posts
Posted October 25, 2014 - 03:59 PM
If anyone has an oem original belt to interchange maybe I could help.
Normally the starter belts are cogged or have a deep groove to grip the pulleys better, the one in the pic above looks like a regular v belt and rides too deep in the pulley.
  • superaben said thank you
#5 EricFromPa OFFLINE
EricFromPa
  • 3,523 Thanks
  • 3,070 posts
Posted October 25, 2014 - 08:02 PM
Na it's a Deep groove belt.It may be the original belt it's worn very badly.It's V goes the whole way to the bottom of the pulley and is worn to a Point.But still starts the tractor fine Doesn't slip either lol.I'm pretty sure I'll be replacing it if I can't sell the tractor soon.
Winter is coming Fast.If I can't sell it soon I'm gona get it ready for Snow duty.
#6 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted October 26, 2014 - 10:13 AM
Thanks for the replies. I have measured the belt twice and it is 32" long. The pulley on the generator is 3". I guess at this point I will just get a longer belt. I also picked up a free cub cadet 2146 with 286 hours on it. Anyone have some insight into this machine? Thanks!
