Building A Puller
186 replies to this topic
#91 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 05, 2015 - 08:52 PM
Mike I have it set to 4000 and put up the pump a bit as well. Stock was 3200 .. Drove it around some today to tweak the clutch and brake. very happy with it..
Edited by Saxist, March 05, 2015 - 08:55 PM.
  • Alc and superspeedex have said thanks
#92 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 06, 2015 - 06:02 AM
Need to see some videos of this!
#93 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted March 06, 2015 - 09:07 PM
Do you plan on trying to get more rpms out of it? Theres 2 ways can achieve that
#94 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 08, 2015 - 11:41 AM
Mike going to try it for now with this setup but who nows after a few pulls I might want more..I will get a few videos after I get my rims on next week..
Edited by Saxist, March 08, 2015 - 11:42 AM.
#95 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 09, 2015 - 02:42 PM
Picked up my rear rims today and got the tires mounted. Those Tru power tires bulged a bit on the sides and ended up rubbing on the inner fender. So started looking around for some spacers and realized the old axles would do the trick. I drilled out my axles and replaced the wheel bolts for studs and chrome nuts. I left 8 inches of the axle and killed two birds with one stone. I had 1/4 spacers and a shaft to add wheel weights. It worked out well.
  • bgkid2966 and superspeedex have said thanks
#96 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 09, 2015 - 02:44 PM
hope to have my front rims next week.... a money thing lol
Edited by Saxist, March 09, 2015 - 03:19 PM.
  • bgkid2966, superspeedex and Ron Dziedzic have said thanks
#97 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted March 09, 2015 - 02:59 PM
I have one observation, the spring clip probably wont keep the weights on a rotating shaft. I dont even trust them for weight lifting. Are the weights locked on or will they act like the spinner hub caps when you stop?
#98 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 09, 2015 - 03:20 PM
yah that spring clip is temporary I will use set screw type for a lock
Edited by Saxist, March 09, 2015 - 03:20 PM.
#99 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted March 10, 2015 - 09:44 PM
Looks good i seen your posts on facebook. Did a good job with it
  • DaveBb said thank you
#100 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 12, 2015 - 09:13 AM
Thanks Mike.... Today I completed the weight racks. This is something that bothered me. I noticed that guys hang weights without any consideration for the looks.  I have four places for weights.... a tray under the wheelie bars holds 70 pounds of flat stock. Behind the seat weider cast weights 100 lbs. Then on the wheels 55 each side and finally the big one under the tractor will hold 340 lbs. That round bar slides out when not in use seen a few guys smack there shins on these things. That gives me a grand total of 620 Lbs. At a cost of a buck a pound plus tax ug a expence I forgot about.  Just need to put on the front rims/tires  and finish making my seat cushion and its done...  :firejumper:
Edited by Saxist, March 12, 2015 - 10:20 AM.
#101 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 12, 2015 - 10:21 AM
After some thought I decided to add a spot out front for another 20 lbs in case she lifts to much...the bar can be removed when not used..
Edited by Saxist, March 12, 2015 - 10:22 AM.
#102 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 14, 2015 - 08:57 AM
I liked the diamond plate seat but was very hard on the butt so I used the wifes sewing machine and made a cushion. I used 2 inches of memory foam and 10 bucks of vinyl.
Edited by Saxist, March 14, 2015 - 08:59 AM.
#103 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 21, 2015 - 09:55 AM
Looks great, this is a picture of how you need to cut tires to work.
  • superspeedex and DaveBb have said thanks
#104 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted March 22, 2015 - 06:12 AM
Going to need to do more than that for them tru-powers to work. The tread angle is not as straight as the Firestones or even Lawtecs, this will cause to much shear.But they can be ground up to help this, you just need to be careful and plan your cuts
#105 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted March 22, 2015 - 11:05 AM
our tracks are hard clay nothing soft around here. I seen guys smoke there tires it gets so hard after a few hours. So I need to cut a relief on the top so the front of tread is higher?  Its done cept the air filter I am waiting on. Was a fun build but of course it cost twice as much and took twice the time I expected.. lol
Edited by Saxist, March 22, 2015 - 11:08 AM.
  • Chris11, skyrydr2, bgkid2966 and 3 others have said thanks
