Building A Puller
186 replies to this topic
#31 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 02, 2014 - 08:49 PM
To flip the axle I had to do some changes to the stearing linkage. I removed the drag link arm now on the bottom and welded it to the top. I cut the stearing knuckle shaft shorter and put a bolt and washer like the other side
Edited by Saxist, December 02, 2014 - 08:51 PM.
  • superspeedex, CharlesDes and laurarg3 have said thanks
#32 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 02, 2014 - 09:04 PM
Got some more parts sandblasted and primed. Welded a heavier plate for the clutch bracket.
#33 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 05, 2014 - 02:42 PM
Well got the body parts painted up today. Epoxy primer then three coats of sublime pearl base coat followed by two coats of PPG clear. The engine and hood are almond color. Going to use the older international red black hood stickers. Not sure yet fenders will be custom made and round maybe stainless.
Edited by Saxist, December 05, 2014 - 02:44 PM.
#34 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 10, 2014 - 11:51 AM
Well had a productive morning I made the two foot rest, and the seat from diamond plate aluminum. Its tuff doing nice clean bends when you don't have a brake  :wallbanging:  .  Also was able to make the headlight plate from stainless that still needs some buffeting.
Edited by Saxist, December 10, 2014 - 12:02 PM.
  • Sawdust and superspeedex have said thanks
#35 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 10, 2014 - 11:57 AM
Got the hood painted. I did almond base clear topped off with a new chrome emblem. The dame thing looked like someone shot it with a shotgun. Lots of heating and tapping to get rid of the dings but I am happy with the results.
Edited by Saxist, December 10, 2014 - 11:58 AM.
#36 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted December 12, 2014 - 06:41 PM
WOW this is looking great. I'm diggin the lime green. Good luck.
  • DaveBb said thank you
#37 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 13, 2014 - 02:47 PM
wont be long I will start putting this beast togather. Waiting on diff parts and stearing box bearings.
  • Sawdust said thank you
#38 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 16, 2014 - 10:59 AM
Well got my dash panel done today. Took longer to buff the stainless then it did to do the cut outs..Will need to do a couple notches in the steering column to accept the two outer gauges.
Edited by Saxist, December 16, 2014 - 11:01 AM.
#39 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,334 Thanks
  • 1,518 posts
Posted December 16, 2014 - 09:37 PM
I have a YouTube with all of us diesel guys here in southwestern pa. Right now im about 35 pounds of boost at 5000 rpms with no work done. Just a heavy govenor spring, small turbo and a heavy billet flywheel. Looks good so far.
  • superspeedex and DaveBb have said thanks
#40 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 18, 2014 - 12:44 PM
Started putting the beast back togather...
  • bgkid2966, Sawdust and superspeedex have said thanks
#41 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted December 18, 2014 - 03:35 PM
i like those colors
#42 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 19, 2014 - 11:31 AM
Well got the front end sorted out this morning. I used 3/16 expanded aluminum that looks almost exactly like original. The top part is buffed stainless. The sticker is cut from the dash decal of a 70..
Edited by Saxist, December 19, 2014 - 11:34 AM.
#43 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted December 19, 2014 - 12:00 PM
Decided to give the Cub a proper name.... Rip and Tear
Edited by Saxist, December 19, 2014 - 06:03 PM.
  • EricR, Sawdust and T Guiles have said thanks
#44 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted January 23, 2015 - 12:46 PM
Well I finally got the diff sorted out. It seems it will be the most demanding and costly part of the build. So here is a list of what I did.
Replaced Carrier for later model bolt togather type.
Replaced axles for fine spline.
Replaced axle bushings for needle bearings.
Replaced all seals.
Replaced all bearings and cups.
Replaced shift forks for heavy duty.
Replaced input shaft.
Replace internal brake disks
Leather shifter knob
The other thing I did was had a heavy duty bearing holder made for the front of the pinion shaft. When you flip the carrier the strain is then pulling on the front bearing of the shaft and that snap ring is not up to the job. Total cost $805.00 that does not include the beer and coffee and bribe cost to the wife for letting me get it done. :-)
  • bgkid2966, EricR, Sawdust and 1 other said thanks
#45 DaveBb OFFLINE
DaveBb
  • 394 Thanks
  • 170 posts
Posted January 23, 2015 - 02:45 PM
Got my steering wheel done today also. Kinda made my own thing using the original hub. Cut some stainles plates welded them in.  Made a two spoke wheel so I can see my gages. I bought a black steering cover that I cut shorter then glued it to the outer rim.
Edited by Saxist, January 23, 2015 - 02:47 PM.
  • EricR and Sawdust have said thanks
