Kubota Compact Alternater Repurposing
9 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,242 Thanks
  • 9,184 posts
Posted October 23, 2014 - 06:19 PM
I was looking at a Grasshopper mower with a Kubota 721 diesel engine. It had this little alternator on it.
http://www.amazon.co...K?tag=myfida-20
Has anyone tried retrofitting one of these to a GT? Were there any issues wiring the 6 wire rectifier in? This seemed like a good way to add charging to a tractor.
Edited by LilysDad, October 23, 2014 - 06:23 PM.
  • hamman said thank you
#2 olcowhand OFFLINE
  • 38,833 Thanks
  • 30,707 posts
Posted October 23, 2014 - 06:44 PM
Much easier to just get an internally regulated one wire 40 amp alternator.  HERE
  • MH81, Alc and LilysDad have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,242 Thanks
  • 9,184 posts
Posted October 23, 2014 - 07:01 PM
One wire? I suppose it's grounded. Where does the one wire go?
#4 olcowhand OFFLINE
  • 38,833 Thanks
  • 30,707 posts
Posted October 23, 2014 - 07:10 PM
To your ammeter, or key switch.  If using an ammeter, you'd still need to run it through your key switch to prevent drain when engine is off.  You would wire it to the accessory pole on the key switch.  If you put it on the ignition pole, the alternator may keep the ignition firing even when the key is off.  I am using 2 of these alternators.
  • sacsr and LilysDad have said thanks
#5 Cvans OFFLINE
  • 6,017 Thanks
  • 5,874 posts
Posted October 23, 2014 - 08:09 PM
I'm running one of those dynamos on the diesel in my golf cart. I didn't have room for an alternator. It puts out enough to keep up with all the lights so that works for me. In the past we have had several engines with those on them and never had a problem. I think they put out something like 14 amps.
  • LilysDad said thank you
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 23, 2014 - 08:12 PM
Odd little gizmo...I use the $10 nater from the junk yard most times..
Edited by Auburn, October 24, 2014 - 11:19 AM.
#7 Cvans OFFLINE
  • 6,017 Thanks
  • 5,874 posts
Posted October 23, 2014 - 10:28 PM
I purchased one of those and it didn't last 50 hours. Don't think I'll buy another.
Edited by Cvans, October 24, 2014 - 10:03 AM.
#8 TAHOE OFFLINE
TAHOE
  • 7,740 Thanks
  • 5,580 posts
Posted October 24, 2014 - 07:50 AM
I ran a GM 2 wire on my Sears for a bit when I couldn't afford to get cahrge system fixed, I just happened to have 4 off htem lying around from my hot rod days. Worked well, but bulky and I had an over charging issue. Had it on a separate switch so I could turn charging off/on when ever I wanted
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,242 Thanks
  • 9,184 posts
Posted October 24, 2014 - 09:17 AM
Does a 40 amp altern' work with a GT battery?
I'm trying to think where I would run one on a Wheel Horse. I can run it off the pto if I want to turn it off and on with the pto clutch.
Edited by LilysDad, October 24, 2014 - 09:19 AM.
#10 Cvans OFFLINE
  • 6,017 Thanks
  • 5,874 posts
Posted October 24, 2014 - 10:02 AM
Yes that alternator works with the GT battery.
  • LilysDad and Auburn David have said thanks
