I Would Love To Have One Of These!wow
6 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 20, 2014 - 10:56 AM
  • MH81, Texas Deere and Horse, IamSherwood and 2 others have said thanks
#2 Jazz OFFLINE
Jazz
  • 2,309 Thanks
  • 1,408 posts
Posted October 20, 2014 - 12:25 PM
Preferences
Preferences
 My son is a journeyman boilermaker and they only use oxy/acetylene and I know in trade school they were cutting steel 12" thick so as slick as this "petrogen" may be there must be a reason it is not more prominent in the industry. Could be something as simple as the company having to promote itself more as acetylene is stinking expensive. Myself I use oxy/propane. I try to avoid using torches for various reasons...my favourite tool for cutting steel is band saw. I set a platform in the vise to make the saw more versatile..
Edited by Jazz, October 20, 2014 - 12:25 PM.
  • CRFarnsworth, boyscout862, Nato77 and 5 others have said thanks
#3 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted October 20, 2014 - 03:37 PM
For many years I've used oxy/propane. Personally I think this the cheaper way to go, for normal cutting use. I can see were a petrogen system would be better for certain instances. When I was heavy into scraping I would go through about 5-6 of the bigger bottles of oxygen to 1 20# bottle of propane. I was cutting through 4" material some days without a problem. The only down side is it takes a little longer to warm the metal to start your cut. For brazing or soldering a oxy/acetylene setup I think would be better.
  • propane1, Auburn David and holdenboy1960 have said thanks
#4 Bill 76 ONLINE
Bill 76
  • 1,892 Thanks
  • 1,178 posts
Posted October 20, 2014 - 04:50 PM
Might be a money saver for someone that does a lot of scraping.I have an oxy/acetylene set up and use it for heating rusty stuck parts or for heating steel for bending.
I use plasma cutter for cutting,lots faster and allmost no destortion plus you can cut aluminum and stainless and the bonus is the only cost to run is what I pay for electric to run machine and the air compressure and new tips when needed.
#5 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted November 05, 2014 - 02:05 AM
For the thinner stuff up to about a 1/4", when cutting for precision, multiple angles etc. I use a die-grinder or a right angle grinder with a cutoff wheel.
When just cutting off steel, I have one of those chop saws that uses a carbide tipped blade, not a wood blade but a blade made for cutting steel. That is a slower rated of RPMs than a regular cutoff saw that uses a grinder blade.
The carbide tipped blade leaves the steel, even thick steel, just barely warm to the touch.
For thick steel, I use My oxy/acetelene torch. Use that for freeing rusted on bolts too, as mentioned by Bill 76.
That Petrogen system looks mighty impressive cutting through that much steel, multi layered at that too, even the one where there is a big gap between the two layered steel.
Might have to check into that.
  • Nato77, Auburn David and holdenboy1960 have said thanks
#6 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted November 05, 2014 - 07:34 PM
Smoke and mirrors the gas has nothing to do with cutting thick steel. The ox pressure is what doing the cutting. As far as under water its a internal mix torch. The tip looks like a 5 or 6. We usually run 2.5 tip and we use propane. A little tidbit when you get a cut going you don't even need the gas the oxygen alone will oxidize the steel the gas is just needed to get it to molten stage.
  • Auburn David and holdenboy1960 have said thanks
#7 MrMarty51 OFFLINE
MrMarty51
  • 141 Thanks
  • 105 posts
Posted November 06, 2014 - 04:16 PM
It almost appears, in one of the cuts, that the flame had been turned to almost nothing, just oxidation going on.
