Cleaning My Engine After Removal
10 replies to this topic
#1 VillageGreenDeere OFFLINE
VillageGreenDeere
  • 17 Thanks
  • 32 posts
Posted October 20, 2014 - 06:01 AM
I have a 318.....I'm going to pull my engine to replace the oil pan, and while it's out I want to give the dirty mess a thorough cleaning.  Are there any big no no's to cleaning an engine, outside the obvious keeping water and degreaser out of intake and exhaust?
matt
#2 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted October 20, 2014 - 06:28 AM
I would also try to keep the degreaser off the ignition coil and charging system electrics if they are still on it. Other than that not really an secrets; just get some good degreaser and an old toothbrush works pretty good to get down in the cooling fins.
  • Bill56 said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Posted October 20, 2014 - 07:32 AM
I would just suggest getting the fins as clean as possible, and make sure there is no residue on them when you slap it back in.
#4 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted October 20, 2014 - 07:36 AM
Gas is cheaper, and better, than most engine cleaners.  I use the old stuff I take out of things that I fix.
  • boyscout862, Sawdust and Bill 76 have said thanks
#5 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 20, 2014 - 08:06 AM
Bug and Tar remover also disolves or cuts the grease pretty quick.
#6 Sawdust ONLINE
Sawdust
  • 5,647 Thanks
  • 3,364 posts
Posted October 20, 2014 - 08:53 AM
I agree cleaning with gas like mentioned, that's what I use most of the time.
  • Bill 76 said thank you
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 20, 2014 - 09:00 AM
If the 318 has the Kawasaki engine in it there is an electronic ignition module on the left side (facing rear of tractor) at the back.  I'd cover that up.
  • superaben said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted October 20, 2014 - 05:29 PM
Story goes that in WWII, the air force guys used to take aircraft fuel and wash the planes with it.  I was told it would take off bugs, crud, and junk that nothing else could.  One guy told me that he had seen it sloshed onto hot engines, and he was always surprised he lived to tell about it.
That was during the gas shortage in the states, too!
Ben W.
#9 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted October 20, 2014 - 07:45 PM
gasoline was first use to clean things - before they started using it in engines
#10 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 21, 2014 - 10:33 AM
When I redid my 120 prepped my engine for paint with the following steps:
  • power washed with all tin in place (after removed from the tractor and was careful to not get electrical parts wet when possible, especially points)
  • removed tin, sprayed all parts down with Simple Green, scrubbed with soft bristle brush, rinse with power washer under low pressure
  • removed old paint with wire wheel and wiped down with tack rag
  • Repainted block with high-temp paint (taped off head and left bare aluminum)
  • Painted tins with regular paint that matched the high-temp stuff on the block
  • Reassembled and installed in the tractor
I used JD Muffler black paint for the block and JD Blitz black for the tins.  There is very little difference in color and shine on these two paints.  Over time the paint on the block cooling fins has dulled a bit.  As of know I believe the engine has about 50 hours on it since the resto.
#11 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 21, 2014 - 06:35 PM
Oven cleaner is good for paint removal for the block. Not the environmentally nice stuff though that
smells like lemons. Use the old fashioned stinky stuff.
