654 Question
5 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted October 18, 2014 - 09:13 PM
My wheelhorse is stuck in 2gears question is is there anyway to get it out with out taking the thing apart?
And is there a service hole where I can get to the shift forks?
#2 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted October 20, 2014 - 10:04 AM
Yes, there is. Pull the shifter out and look down the hole. Get them lined up and reinstall the shifter. I don't have a picture but it will be obvious when you look in there.
  • bryan 110 said thank you
#3 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted October 20, 2014 - 05:16 PM
Ok I'll give it a shot
#4 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted October 21, 2014 - 06:34 AM
I found a picture for you. This is in the neutral position. Use a screwdriver to position both forks like this. you'll feel then kinda lock into place. Make sure the shifter is adjusted properly. If the problem persists we'll go a step further.
#5 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted October 26, 2014 - 09:04 PM
Got the shifting fixed now I need a new motor. For the life of me my dad and a old bus mechanic we can't seem to finger out why the motor won't start we have gas we have spark and all the necessary thing but just won't go. It dose run when it wants to but when we want it to nothing. Last Friday it started right up now today after cranking on it for a hour and a half nothing. It has a unknown brigs motor in it that looks like a mouse ate half the wires off of it and been put back together.
#6 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted October 28, 2014 - 04:28 PM
Glad you got the shifting issue fixed. The 654's originally had Tecumseh motors so yours is a transplant. The first thing I'd do is repair/replace all the damaged wiring. With the problem being intermittent it likely is in that wiring.
