My Snowblower Creation
16 replies to this topic
#16 diesel nut ONLINE
diesel nut
  • 716 Thanks
  • 435 posts
Posted November 09, 2014 - 04:25 PM
Why don't you buy a cheap winch from Canadian Tire and use the winch to turn your chute. Its easy enough to do. I also  use a window motor to activate my deflector on my blower. I did use a window motor for the chute control on one of the blowers.It was easy to do because it had a spiral crank so I used the window motor to turn the crank. I'll post a couple pics so you can see how easy its to do.
That window motor and regulator setup is a good idea.  I've got a couple laying around after fixing my truck doors, have to see if I can make them work on one of mine.
#17 truckintyler OFFLINE
  • 90 Thanks
  • 63 posts
Posted November 19, 2014 - 04:12 PM
Only got about 7cm here in napanee, I feel bad those of you in buffalo.
Ransomes has seemed to work pretty well, both chutes are using Honda accord window motors.
Bought a yellow light, next will be a electric salter on the rear.
  • Bruce Dorsi, IamSherwood, LilysDad and 1 other said thanks
