It works...
6 replies to this topic
#1 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 04, 2010 - 10:07 PM
I started by hooking up a new receptacle for my welder, but I ended up re-wiring the whole circuit with heavier wire and breaker.
I tested the circuit with my compressor, it worked great. Now to test my (new to me) welder.
The spool works, check.. the gas works, check. Now a test weld.
Not too bad considering it the very first time I have used the welder and I have no idea were to adjust the settings. Also, this weld was done with straight Argon.
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 4,762 Thanks
  • 5,374 posts
Posted March 04, 2010 - 10:17 PM
Good stuff
#3 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted March 04, 2010 - 11:00 PM
Yea, looks good. If that is 1/4 inch plate, I think 200-210 inches per minute and 18-18.5 volts would be right. The welder should have a chart in it somewhere for these settings.
#4 mjodrey OFFLINE
  • 2,351 Thanks
Posted March 05, 2010 - 05:35 AM
A-one .:thumbs:
#5 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted March 05, 2010 - 10:08 AM
Yes, the welder has a chart on the inside panel. I knew that the heat setting was too low before I even started. I was just laying a test bead, so I did not need great penetration. I just want to make sure it worked okay.
I also wanted to see how the 100% argon would do, I have always used a 80/20 mix in the past.
#6 NUTNDUN OFFLINE
  • 10,282 Thanks
Posted March 05, 2010 - 10:20 AM
Looks like it is going to work out perfect for ya and definitely worth what ya paid. I would love to have a bigger welder but I don't think I can really justify enough welding to warrant a larger welder.
Good job though :thumbs:
#7 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted March 05, 2010 - 10:25 AM
From what I understand, with straight argon on steel, the bead will be a tad taller as penetration is slightly less. Requires welding a bit higher on amperage to compensate. Your weld looks GREAT to me! :thumbs:
