Amp Meter Hook Up, Help
20 replies to this topic
#16 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 15, 2014 - 07:14 PM
Hummm On this setup a "battery level" gauge might have to go on D...or else it would be hot all the time on A????
#17 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 15, 2014 - 10:20 PM
Just remember w/ an ammeter to use the same size wire as you splice into. If the wire is too small the alternator can't charge the batt as fast as it should.
Mike
#18 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted October 16, 2014 - 08:03 AM
I took a look it last night. The connector has six wires. 3 wires over 3 wires. I tested for voltage on all the wires and here is what I came up with....
The red wire is hot all the time. The yellow and green wire are both hot with the ignition on.
  • Auburn David said thank you
#19 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted October 27, 2014 - 08:43 AM
I finally got the amp meter hooked up. I put it in series with the feed to the fuse block.
It seems to work okay.
  • olcowhand, Alc and Auburn David have said thanks
#20 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted October 27, 2014 - 07:25 PM
With the battery level gauge it must be hooked up to a wire that is hot when the switch is in both the start and run positions.  With battery ignition I just run it off the coil hot wire.
#21 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted October 28, 2014 - 09:55 AM
This is a diesel with a dynamo, so the normal hook up methods don't work.
It seems that putting the amp gauge in line with the supply line from the dynamo controller to the main fuse block is working.
