Need Advice On Delco-Remy Starter/generator
16 replies to this topic
#16 EricFromPa ONLINE
EricFromPa
  • 4,185 Thanks
  • 3,356 posts
Posted October 21, 2014 - 02:57 PM
BIG UPDATE!!!
It Runs It Runs.
It has about 5 hours on it.Just changed the oil for the 2nd time.I think it's Good to go.
Warning Very Pic heavy Post.
And it runs REALLY good.Here's some Pics and a short video.
Thank you all again.
I have a bit of vibration from a dry rotted and cracked rubber Drive shaft coupler but other than that she runs super smooth.
She's in really good condition for never having been repainted.Has a few scratches but no dents what so ever and very very little rust.
Edited by EricFromPa, October 21, 2014 - 03:03 PM.
  • Sawdust said thank you
#17 Jazz OFFLINE
Jazz
  • 2,677 Thanks
  • 1,549 posts
Posted July 18, 2017 - 05:57 PM
I'd check the ACR. I had two Kohler engines do the same thing you are describing. Both where 12 hp engines in a 128 and 129. They weren't rebuilt but one started fine then suddenly was near impossible to start with the starter generator. I also tried multiple starters on each engine.
I think this is issue with my tecumseh on my SS12I.  Bench tested starter generator and it spins fine but turns engine slowly. Cleaned up starter inside and it did speed things up a bit.  If I boost tractor with my truck it starts/runs fine but thats the only way it will start,  it demands huge current.
I just pulled spark plug and engine spins over like it should!  I suppose this means valves need adjusted. What do you think?
Edited by Jazz, July 18, 2017 - 06:11 PM.
