Bringing A 1966 Massey 10 Back To Life
26 replies to this topic
#16 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted October 29, 2014 - 01:04 AM
There is this guy who lives near you who has an attic full of JD stuff, probably a seat up there you can get by with for now. :poke:
Glad you got the tires, best weight them down and get some chains if you plan on doing serious damage this winter.
  • IamSherwood, KennyP and johndeereelfman have said thanks
#17 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted October 29, 2014 - 01:06 AM
:bigrofl:
#18 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted October 29, 2014 - 01:09 AM
:bigrofl:
Yeah, laugh now... Wait until Troy sees that.
  • C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_images.jpg
#19 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted October 29, 2014 - 03:04 PM
Are you going to chain up, and load those rear sneakers?
Yes, it's getting weights and chains the parts tractor has weights mounted on inside of rim that I need to take off yet
#20 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted October 29, 2014 - 03:05 PM
Ah yes a J.D seat to go with the brake band. :D
  • MH81 and johndeereelfman have said thanks
#21 johndeereelfman OFFLINE
johndeereelfman
  • 5746 Thanks
  • 2611 posts
Posted November 01, 2014 - 02:45 PM
:bigrofl:  :bigrofl:  :bigrofl:  ................NOT!  :poke:
Edited by johndeereelfman, November 01, 2014 - 02:46 PM.
  • MH81, IamSherwood and KennyP have said thanks
#22 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted January 24, 2015 - 10:54 PM
I got about 2 hours of seat time on the 66 today.I went to start it this morning and it barely cranked over.I had to jump it with my truck.The charger didn't even help.Once I got it running I started plowing and made 3 passes,then the engine started bogging down like it was under load.I found that the belt came of of the tensioner pully and wedged between  frame and pully.I got the belt bake on and made 2 more passes.It came of again.Each time I shut it off and had to jump it with the truck.After that I was able to finish my parking area and 3 neighbors.It plowed great we had about 3in of heavy wet snow.I brought the 67 home tonight and got the plow switched around.I want to be able to jump on start w/no issues and plow not having to jump start it everytime I shut it off. On the 66 I want to get the starter generator rebuilt,and figure out whats up with the belt.It figures when I first mounted blade I leveled a stone pile in back of my garage with no issues.
  • IamSherwood said thank you
#23 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 25, 2015 - 06:34 AM
Check to make sure the rear end isn't loose in the frame. Sorry you had issues.
Bearings for the s&g are std size and available at most bearing places.
  • IamSherwood and ckjakline have said thanks
#24 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 25, 2015 - 09:30 AM
Looking at the tensioner in the 3rd pic in this post
http://gardentractor...fe/#entry501538
It looks a bit cockeyed. Maybe the bearing in there is kaput.
  • ckjakline said thank you
#25 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted January 25, 2015 - 11:58 AM
Will I see what you mean i'll have to pull the side cover and check that out.Good eye.
#26 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted January 25, 2015 - 12:01 PM
Alan, I think I remember you doing a thread on rebuilding Ryans starter generator.Did you have that in the mechanical forum or the Massey forums.I want to find that tonight and take notes.I'd like to rebuild mine myself so I know how to do it.
#27 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 25, 2015 - 01:07 PM
Here you go
http://gardentractor...se/#entry295834
