1556 Trans Problem
#1
OFFLINE
Posted October 11, 2014 - 06:39 PM
We'll damm I could not get the page to copy and paste. But in manuals you can find it under the eaton 10 service manual.
Has any one had this problem in the past?
#2
ONLINE
Posted October 11, 2014 - 06:43 PM
Sorry I cant help on this, I never worked on an Eaton transmission so have no tips or advice to offer
- Rainier said thank you
#3
OFFLINE
Posted October 11, 2014 - 06:55 PM
If I knew what manual to use for this, I might be able to help. I looked through the bolens section, but could not find a 1556 manual!
#4
OFFLINE
Posted October 11, 2014 - 07:05 PM
- KennyP said thank you
#5
OFFLINE
#6
OFFLINE
Posted October 11, 2014 - 07:26 PM
This is a hydrostatic drive tractor, so you should not be able to push it without "relieving" the pressure or putting it into neutral.
If it is able to freewheel, it sounds like it is bypassing. That means it is allowing fluid to escape from the pressure circuit that makes the wheels go.
It could be as simple as a relief valve.
Ben W.
- sacsr and Rainier have said thanks
#7
OFFLINE
Posted October 11, 2014 - 07:50 PM
And if you have to replace it where do you find parts?
#8
OFFLINE
Posted October 11, 2014 - 07:52 PM
#9
OFFLINE
Posted October 11, 2014 - 07:55 PM
#10
OFFLINE
Posted October 11, 2014 - 08:00 PM
M 1556 had to be in neutral {just let the pedal ride between forward and reverse} to move it and it would make a clicking noise.
#11
OFFLINE
Posted October 11, 2014 - 08:32 PM
- greenhouse guy said thank you
#12
OFFLINE
Posted October 11, 2014 - 10:21 PM
As far as the pulley release, it makes no difference wether it is on or off when pushing it around.
#13
OFFLINE
Posted October 11, 2014 - 10:27 PM
So you. Believe that the clicking noise is normal. That make me think more about the tension spring. It would be a easy fix,
#14
OFFLINE
Posted October 12, 2014 - 06:40 AM
[quote name="PappyH" post="500687" timestamp="1413075610"]M 1556 had to be in neutral {just let the pedal ride between forward and reverse} to move it and it would make a clicking noise.[/quote
My H16 makes the same sound as well you can only push a couple feet then the rear lock up from pressure. These have no real neutral and they are not really meant to be pushed far at all.
#15
ONLINE
Posted October 12, 2014 - 07:29 AM
These really were never made to be "Freewheeled" for long distances.
If you had to manually move them it was recommended you go very slow, the clicking is normal when pushing.
