Can anyone identify these implements?
9 replies to this topic
#1 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 18, 2011 - 08:39 AM
Who made them?
They don't look homemade.
As you can see by the tape measure, they're not Cat 0. (that should be 16")
I got them last fall with a MF8. Someone had homemade a 3pt hitch on it
with a linear actuator. Pretty crude build, but functional. I plan to rebuild
it when I do that tractor resto this summer.
There are no markings on the imps.
The blocks holding the disc shafts are wood.
#2 Bolens 1000 ONLINE
  • 15,433 Thanks
  • 18,286 posts
Posted February 18, 2011 - 08:57 AM
Maybe Brinley?
Thats just a guess though....
#3 mjodrey OFFLINE
Posted February 18, 2011 - 10:10 AM
Maybe Brinley?
That would be my guess too.
  • 14,889 Thanks
  • 15,514 posts
Posted February 18, 2011 - 11:27 AM
If you unbolt something on each one of them, you might be able to see the original paint in between the pieces. I agree with Doc, Brinley most likely or Wheel Horse maybe.
#5 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 18, 2011 - 11:39 AM
Isn't that the width of Sears 3 point hitches? I'm thinking David Bradley.
#6 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted February 18, 2011 - 11:51 AM
You may be right about Daniel, and I just looked at some sears stuff yesterday, didn't measure it.
#7 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted February 18, 2011 - 12:08 PM
The width is right for a sears style 3pth. The top link is wrong for the sears style. On the sears the toplink itself is the clevis. Didnt brinly make alot of the GT implements for all the different tractor manufacturers?
#8 MH81 OFFLINE
  • 29,979 Thanks
Posted February 18, 2011 - 01:01 PM
You beat me to it. At first I thought someone took some older sears implements & upgraded them, but They look factory & the plow hook points are different. I think these are factory, supposed to be "Cat 0" but were actually a little smaller. If I had to bet, I'd say Brinly or David Bradley also.
EDIT; I knew I'd seen a pic recently of a Brinly Disc... Brinly Discs
I'd say they're not Brinly
#9 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 18, 2011 - 02:20 PM
When I said David Bradley, I still figure they were made by Brinly for DB. Most tractor manufacturers farmed out the implements, then put their badge on them.
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 19, 2011 - 01:16 PM
Don't be afraid of those Wood boxing Bearings. Back in the early 60's My Dad sharpened discs for farmers in several countys.
It was my job to take the sections out of the frame so he could mount them in his gas powered lathe, built as a trailer.
Most of the discs had greaseable oak bearings in cast iron boxes. At the slow field speeds if greased properly and regularly those bearings would last indefineately.
You have a NICE collection of implements!
