I Need A Little Refresher.........
3 replies to this topic
#1 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted October 07, 2014 - 03:52 PM
course on checking the output of the Delco Remy starter generator on my Homelite. I just can't seem to figure it out. The book I have is lent out and my friend is gone hunting until next week. It may just be that the battery is to weak. I was tilling under the garden when the tiller didn't want to lift all the way. Now I did have to jump the battery to get it started but I figured the generator would put out enough to let me  till it. It's not that big. Going back put now to try it again. I do have three more SG if I need them.All were in good shape when put away.  Thanks for jogging the memory of this old man.        Roger.
#2 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted October 07, 2014 - 04:00 PM
Casey did an article on testing these.  You can find it HERE
  • Bill56, hamman, wvbuzzmaster and 4 others have said thanks
#3 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted October 07, 2014 - 10:03 PM
Before removing anything did you check voltage output while running?   I measured my s/g once it put out 15 volts on one pole, 11 on the other.  B+ on the reg should convert that to 13-14.  If you're getting 13+ at battery the charging system should be ok good luck
  • hamman said thank you
#4 hamman OFFLINE
hamman
  • 6,597 Thanks
  • 2,908 posts
Posted October 08, 2014 - 08:30 AM
Going to do the checking today. I did a quick test yesterday and it showed it was putting out 14 (analog meter) at the B lug. Appears to be same at battery. More extensive today. Might be that the battery is getting weak. I can't remember the size the battery is supposed to be so I just bought a NAPA GT battery.  Thanks.        Roger.
