Jaques Mighty Might Project. Almost A No, Now A Go!
44 replies to this topic
#16 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 09, 2014 - 09:12 PM
I'm having a good time with the parts gathering MH81. I wish there were enough good parts to make two, but it just can't be done at this point.You never know what could be just around the bend though. The cheap parts Mighty Mite from CT was an absolute surprise, and the '48 dated crusty ZZ engine with the twin disc part I needed was one heck of a coincidence. I have to save a few bucks for paint, tires, some gasket material and some seals, but this project should move right along now.
Edited by classic, December 24, 2014 - 07:24 AM.
#17 Sawdust ONLINE
Sawdust
  • 5,674 Thanks
  • 3,378 posts
Posted October 09, 2014 - 09:29 PM
Wow what a ride on this one parts falling right in front of you. This will be another interesting project to follow. I'm amazed too sometimes how these tractors seem to just go to sleep until someone wakes them up & their ready to serve again. It's a good feeling.
  • MH81 and classic have said thanks
#18 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 09, 2014 - 10:03 PM
It sure is a good feeling bringing them back to life. There's something about old machinery that just speaks.
#19 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted October 09, 2014 - 10:25 PM
So.....that's what that is. I always thought it was the voices in my head.   :smilewink:
The project is looking good. Sometimes its amazing how things fall in place.  :thumbs:
  • KennyP and classic have said thanks
#20 MH81 OFFLINE
Posted October 09, 2014 - 10:33 PM
  • DougT, KennyP and trowel have said thanks
#21 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 12, 2014 - 04:23 PM
I went down to the neighbors where my Mighty Mite sat in the blackberry bushes for over 8 years. I brought along some tools and completely disassembled the tractor. Everything is actually in real good shape. After cleaning the points, the Briggs model 23 fired right up and ran great. I didn't even have to clean the carb. This engine will go on my '56 Power King, so I can install the ZZ on the Mighty Mite. Well this is where the project will start.
  • MH81, Alc and Gabriel have said thanks
#22 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted October 12, 2014 - 07:17 PM
Looks like a good start, so simply built, good old Briggs, at least you know the coil is still good.
  • classic said thank you
#23 icecream4070 OFFLINE
icecream4070
  • 61 Thanks
  • 103 posts
Posted October 12, 2014 - 07:55 PM
What up with the garden master tractor that guy has
#24 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 12, 2014 - 08:01 PM
It looks like the ad on Craigslist for the Garden Master is gone.
#25 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted October 12, 2014 - 08:29 PM
Crap !!
#26 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 13, 2014 - 03:29 PM
A wheelbarrow full of rear end parts. Disassembly was a bit of a pain due to the brake hub on one of the pinion gear shafts being stubborn.Everything looks to be in good shape except for some chips out of the teeth on one of the pinion gears. I'll be using the bull gear and pinion gear out of the other housing that I have. Now to clean, make gaskets, and reassemble.
  • Alc, Bruce Dorsi, trowel and 1 other said thanks
#27 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted October 24, 2014 - 06:41 AM
This is the clutch yoke and pivot bracket for on the back of a ZZ.
  • Bruce Dorsi and classic have said thanks
#28 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 24, 2014 - 01:02 PM
Wow, thanks Doug! These will be fairly easy brackets to make with some patients. Any measurements including hole locations would be very helpful. I do have the measurement for the hole spacing on the bracket that bolts to the ZZ engine block. I just don't know how long the two welded on tabs are on this bracket, or where the pivot bolt hole should be. I would also need the overall length of the fork, and how long the tab that is welded to the fork is. With that info, it will make it a whole lot easier to accomplish.
#29 Tbrooks OFFLINE
Tbrooks
  • 508 Thanks
  • 326 posts
Posted October 24, 2014 - 09:51 PM
Thought I would share with you some pics of my Dads mighty mite. He is almost finished with it. If you need any close ups let me know, I will get them for you.
  • RAJ, Bruce Dorsi and classic have said thanks
#30 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted October 24, 2014 - 10:12 PM
Thanks for the pics Tbrooks, I appreciate it and your dads Mighty Mite looks great! If I need more pics as I move along, I'll be sure to contact you.
  • Tbrooks said thank you
