Thinking About A Diesel Repower.
43 replies to this topic
#16 KennyP ONLINE
  • 40,927 Thanks
  • 47,123 posts
Posted October 07, 2014 - 05:31 PM
Some of those Toro's have a Mitsubishi K3D in them as my 322D has. It runs the Sunstrand off the front end. Has a big flywheel on the back end.
#17 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 06:45 PM
So I am thinking about a v2203 kubota engine for it it looks like not to many mods to make it work
Tim
#18 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 07:05 PM
I just got to find out rotation and height and dem
Tim
#19 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 07:06 PM
Oh man this could be bad lol if this works I could be the owner of a 51 horse lawn mowing Goliath
Tim
#20 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 07:37 PM
That engine runs counter clockwise dang it
Tim
#21 mtoney OFFLINE
mtoney
  • 830 Thanks
  • 693 posts
Posted October 07, 2014 - 07:45 PM
I think alot of the diesels turn that way.  Cub Cadet put the Kubota D600 in backwards to make it work correctly in the older diesel Cub Cadets.  Made for a long radiator hose as Cub put the rad up front instead of burried in the console like JD did on the 330/332.   Mike
#22 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 08:12 PM
That's what I am seeing yanmar does not give a lot of info on the rotation
Tim
#23 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 07, 2014 - 08:36 PM
Tim
They are ALL the same rotation.  You MUST run the hydro off the water pump end of the crank with water cooled diesels.  I'm not sure on all air cooled units as some military air cooled diesels are kinda odd.
  If you want to retain the front pto, you'll need to keep the engine size much smaller than a V2203!
#24 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 09:18 PM
No I got me a frame stretcher lol I am thinking of stretching the frame and making the front frame a little wider and cutting up a spare hood to add to this one so it will look stock but not
Tim
#25 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 07, 2014 - 09:21 PM
Trust me this will be my claim to fame tractor when I get done with it. It might take three or four years but I will get it done
Tim
#26 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted October 08, 2014 - 03:53 AM
That Kubota engine is huge for gt standards. I would look for something no larger that a 1105 series as adapting the crank to fit gt parts will keep a machine shop in the $$$ for months ;-) If you go with the smaller units you may be able to purchase just about everything needed to attach the hydro drive and pto stuffs.
Stretching the frame is an option but can cause all kinds of issues for your attachments later on. If it is just goung to tow around a wagon then fine... But mowing, snow throwing, or what ever else may use front or center pto attaching impements could have issues.
Also tractor Balance front to rear, too much nose weight and you will be spinning everywhere.
My personal prfeference is to make things look and work as if it was a factory install and conpletely intensional by the factory. I dont mind custom hot rods, but perfer a factory version because of practicality, ease of service and parts availability.
How ever you choose, have fun and document it every step so we can follow along :-)
  • Auburn David said thank you
#27 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted October 08, 2014 - 07:11 AM
Is this what you are looking for?
http://newlondon.cra...4702539797.html
  Yanmar Diesel (Danielson)
00s0s_7IxlBMTC56p_50x50c.jpg00G0G_6IrVKwZvO7l_50x50c.jpg01313_9eIUEIcm0Z_50x50c.jpg00F0F_5DLcmjZ4AL9_50x50c.jpg
I have 2 yanmar 3 cylinder engines one is from a john deere f935 and the other is out of a compact tractor
any questions call show contact info
These are near me but I don't know anything about them. Good Luck, Rick
#28 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 08, 2014 - 10:15 AM
Called two guys today that fab frames for race cars and build engines he said throw two feet of frame at it and 6 inches of width and that will allow for the battery and added engine space given dim. Of the 2203 should move the pto forward about four to six inches and the rest is for the fan and radiator and battery to even out the extra 260 pounds to get some more weight to the back of the tractor so it don't just be way to front heavy he is going to do some weight calculations on it in a couple weeks to relocate mule drive and weight distribution
Tim
#29 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 08, 2014 - 10:53 AM
Love my grammar and punctuation or lack there of
Tim
#30 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted October 08, 2014 - 11:48 AM
Still have to figure radiator placement for engine given it is a ccw rotation front long hoses back poor airflow
Tim
