Throttle Cable Won't Stay On 318
7 replies to this topic
#1 abrasv OFFLINE
abrasv
  • 18 Thanks
  • 36 posts
Posted October 06, 2014 - 08:41 PM
Went to mow yesterday and when I pushed the throttle cable to the fastest position it would run there for a few seconds and then slowly slide back to about half throttle. Did that every time I moved it back to fast. Took the air cleaner off and watched it and I could see some part (not sure what it is called) that had a spring on it and looked similar to a vacuum connection on an old car distributor. About a week ago I cleaned and sprayed WD-40 on all the moving parts under the air cleaner. (Guess I should have left well enough alone).
Anyone have an idea about what is causing this?
Thanks,
Jim
#2 HDWildBill OFFLINE
  • 8,978 Thanks
Posted October 06, 2014 - 08:54 PM
Some pics might help identify what you are talking about.
#3 abrasv OFFLINE
abrasv
  • 18 Thanks
  • 36 posts
Posted October 06, 2014 - 09:08 PM
I'm out of town right now but when I get back Friday I'll take a couple pics of the part I'm talking about.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted October 06, 2014 - 09:09 PM
I think it is probably in the handle.  Most of these throttle handles have a rubber washer (or plastic, depending on age) that keeps the lever "tight" without being "snug".  Some handles have nuts and bolts to allow you to tighten it up.
I can't remember what Deere has on the 300 series.  I'll check my 316 and see.
Ben W.
  • abrasv said thank you
#5 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted October 07, 2014 - 05:51 AM
Maybe spray some carb or brake cleaner on the friction washer to clean off the WD40.
  • Alc and abrasv have said thanks
#6 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,020 Thanks
  • 5,980 posts
Posted October 07, 2014 - 06:00 AM
Ben W.
And if you are lucky enough to have a non adjustable handle, use pliers to bend a little kink in the cable when the thing is in idle position.  (whichever side is out of the cable housing) and it will make cable movement more rigid..
  • Alc, superaben and abrasv have said thanks
#7 13jac1316 OFFLINE
13jac1316
  • 4 Thanks
  • 10 posts
Posted October 07, 2014 - 06:03 AM
same thing happened with my 316 we changed the spring
#8 abrasv OFFLINE
abrasv
  • 18 Thanks
  • 36 posts
Posted October 12, 2014 - 08:41 PM
Took a look at it Friday and saw there was a nut and bolt on the handle. It was already pretty snug but went ahead and gave it another small turn and that fixed it.
Thanks all,
Jim
