Removing Paint From An Aluminum Engine Head
7 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted October 06, 2014 - 07:49 PM
Is there any way (besides sandblasting), to remove paint from an aluminum engine head? I was using a wire brush on a cordless drill, but it can't reach all the way down in between the fins. I'm trying paint remover (it's kind of hard to get all the surfaces coated, and, I'm not sure yet how good of a job it will do), but was wondering if there is any other way. Thanks.
Edited by Gabriel, October 06, 2014 - 07:50 PM.
#2 cootertom ONLINE
cootertom
  • 1,632 Thanks
  • 843 posts
Posted October 06, 2014 - 08:04 PM
Sand blaster with crushed walnut shell is what I use.
  • Alc and Gabriel have said thanks
#3 Coventry Plumber ONLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
How about a brush that is used to clean copper fittings. U can cut the handle off and clamp in your drill plus they come in a lot of different sizes and are inexpensive . Just a idea I had.
Tom
  • Sawdust and Gabriel have said thanks
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted October 06, 2014 - 08:36 PM
Aircraft Paint Remover does the job for me.
Ben W.
#5 olcowhand OFFLINE
  • 42,885 Thanks
  • 31,934 posts
Posted October 06, 2014 - 08:37 PM
Ben W.
Yep, a paint stripper will sure get in all those hard to reach places.
  • superaben and Gabriel have said thanks
#6 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted October 06, 2014 - 08:47 PM
Is it better than paint remover?
#7 glgrumpy OFFLINE
  • 8,800 Thanks
  • 8,009 posts
Posted October 07, 2014 - 07:36 AM
Just blast it, OR, get it blasted. All those removers will be hard to get out of fins and may dry down deep and the head will still look old and used. Blasting makes look brand new!
  • Gabriel said thank you
#8 TAHOE OFFLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted October 07, 2014 - 08:41 AM
I use a cautic solution ( sodium hydroxide) to remove colored anodizing when I was polishing aluminum parts from my old Chevy.
Since you probably don't have access to that, I would go with the aircraft stripper from Autozone or Advance auto. It works well and doesn't damage metal.
