Snapper 1855A Work In Progress
31 replies to this topic
#16 adolphsson09 OFFLINE
adolphsson09
  • 258 Thanks
  • 327 posts
Posted October 05, 2014 - 06:26 PM
I got the whole transaxle replaced I bought a parts tractor from Petenpole I will put up pictures here later
  • olcowhand, limebuzz and KennyP have said thanks
#17 adolphsson09 OFFLINE
adolphsson09
  • 258 Thanks
  • 327 posts
Posted October 06, 2014 - 01:35 PM
Heres a couple more pics I have some touch up to do and the 3 point hitch She is still a work in progress Its not perfect but it was in really bad shape when I got it I NEED THE BRACKETS TO MOUNT IF ANYONE HAS A SET OR WILL MAKE A SET THAT WOULD BE GREAT
  • limebuzz, FrozenInTime, Gabriel and 1 other said thanks
#18 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1086 posts
Posted October 06, 2014 - 03:26 PM
That's one sharp looking Snapper.
  • adolphsson09 said thank you
#19 FrozenInTime OFFLINE
FrozenInTime
  • 764 Thanks
  • 444 posts
Posted October 07, 2014 - 11:10 AM
Nice!!
#20 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted October 09, 2014 - 12:12 AM
Looks good.I can imagine the amount of time that you've spent on getting it all fixed up. These tractors were way ahead of there time back then. There a very powerful machine ,comparable to the Sub Compacts now. You'll enjoy using it that's for sure.
I have a 1655 (repowered to 20 hp) and a GC2310. If I had to make a choice, I'd sure miss the backhoe.
  • limebuzz and adolphsson09 have said thanks
#21 adolphsson09 OFFLINE
adolphsson09
  • 258 Thanks
  • 327 posts
Posted October 09, 2014 - 02:33 AM
Wow Tudor one of my tractors has an exhaust guard on it also I thought mine was a loner guess not
#22 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1086 posts
Posted October 09, 2014 - 04:45 AM
That is to keep the exhaust away from the snow blower,so I've read.
#23 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted October 09, 2014 - 09:13 AM
Very nice looking tractor. Nice job.
#24 skyrydr2 OFFLINE
  • 3919 Thanks
  • 3413 posts
Posted October 09, 2014 - 09:24 AM
Boy that sure looks like an Eaton 11 hydro in there?? That unit is really coming together nicely!!
Edited by skyrydr2, October 09, 2014 - 09:25 AM.
#25 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted October 09, 2014 - 11:30 AM
I think you are correct. I think it's connected to Peerless 2600 rear end too, almost exact same set up as in the sears FF tractors.
#26 skyrydr2 OFFLINE
  • 3919 Thanks
  • 3413 posts
Posted October 09, 2014 - 12:57 PM
IF it has an Eaton hydro its a 2500 series and Sundstrand hydro's are the 2600 series both are rated to 20 hp according to Peerless and the 2500 series can have either a regular planetary diff  or a limited slip unit were as the 2600 series can have all of the 2500 series and more with an optional diff lock . As for ratings they are very similar and dependent on axle configurations .hydro unit  Though the 2600 units are usually heavier just because of the hydro unit and the factor of the pass through pump/motor configuration making easier to get a rear pto adapted to the tractor (WAY COOL) . Did any of the Massies have this like the big Deere's did?
#27 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted October 09, 2014 - 01:00 PM
I think Tudor or Daniel will definitely know, I think the Snappers had the Eaton and the Masseys had the Sunstrand, I know my MF has the Sunstrand and 2600
#28 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted October 09, 2014 - 01:23 PM
MF14/16, and MF/Snapper 1450/1650/1655/1855 use the Peerless 2500 final drives on pages 80 - 83 of this PDF. This final drive accommodates both the Eaton 11 and Sundstrand Series 15 hydros. The Peerless 2600 starts on page 84, is visibly different in profile, and will also support both.
I have another link showing the specs for both, but the server at that end currently indicates a problem. Search "Peerless Final Drives" and you may get lucky. My Windows XP is not accessing some sites anymore.
Edited by TUDOR, October 09, 2014 - 01:26 PM.
#29 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted October 09, 2014 - 01:48 PM
Yes, the Snappers all used the finned Eaton 11's.  All the Masseys I've ever seen used the Sundstrand.  I have heard that a few Masseys had Eatons in them, but have never seen one.
  If I'm thinking right, my JD430 and F935's have the 2600 series final drives.
#30 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted October 09, 2014 - 02:24 PM
The early model MF1450/1650's used Sundstrands. After about a year, they switched to Eatons and saved the Sundstrands for the 55 series.
