Jb Weld Didn't Work This Time :(
28 replies to this topic
#16 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted October 04, 2014 - 07:58 PM
Guesses are around 15-16 psi. seems a little high. Should I put the 13psi cap on this? I bought it a couple weeks ago thinking the cap was leaking.
#17 DougT ONLINE
DougT
    Dog Approved
  • 7,072 Thanks
  • 5,058 posts
Posted October 04, 2014 - 08:10 PM
Most of the modern systems run the 15-16 lb cap. Remember that anti boiling is affected by the system pressure.
#18 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted October 04, 2014 - 08:16 PM
would this apply in 1995?
#19 DougT ONLINE
DougT
    Dog Approved
  • 7,072 Thanks
  • 5,058 posts
Posted October 04, 2014 - 08:30 PM
yes
  • larrybl said thank you
#20 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted October 04, 2014 - 09:00 PM
i'll see how well this works then
#21 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted October 04, 2014 - 09:33 PM
We've used jb weld on just about everything on the farm from propane tanks to the hydrants by the barn and chicken coop when they froze and split open this winter. Never another leak. I've even seen in weld used on engine blocks, cylinder walls, and gas tanks with success.
#22 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted October 05, 2014 - 08:51 AM
Yes, Bill. I have used JB successfully on many things, I think the most extreme is on a mower deck mandrel area, and still holding. I was real surprised that the radiator continued to leak.
#23 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,495 Thanks
  • 6,179 posts
Posted October 05, 2014 - 06:27 PM
Jw weld and antifreeze do not seem to mix according to Google search.
Sucks it didnt work but your failure has saved us time.
Edited by toomanytoys84, October 05, 2014 - 07:06 PM.
#24 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted October 07, 2014 - 03:09 AM
1.1 bar is equal to 15.94 psi
#25 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted October 07, 2014 - 12:40 PM
I was installing a radio into a "pipe chaser" Utility truck that had a large water pump. the guage was marked in psi and bar. I was supprised to see 1000psi was around 69 bar. I guess I could have googled it. One concern, the Heater core close to 20 years old, you think I should get a lower psi radaitor cap?
#26 olcowhand ONLINE
  • 42,336 Thanks
  • 31,783 posts
Posted October 07, 2014 - 01:54 PM
The only 2 times I've used JB Weld on a radiator...both miserable failures.  The JB more or less turned to soft goo after a few days.
#27 JohnWR OFFLINE
JohnWR
  • 331 Thanks
  • 337 posts
Posted October 07, 2014 - 09:32 PM
I wouldn't stress that factory is like 14.5 PSI we install those aftermarket rads all the time in those body style camrys and we just use the caps that come with them with no issues at all.
#28 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,010 Thanks
  • 5,978 posts
Posted October 08, 2014 - 02:09 AM
Note to self: Doesn't work as well on aluminum.
Nice Avatar!  Where did you find that??   :D
#29 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted October 08, 2014 - 03:26 AM
Larry, as JohnWR said earlier , don't sweat it , that little bit of pressure difference shouldn't make a difference. . Now if it were a 5-10 psi difference.. That could be an issue for all the old hoses ? But I still think the heater core would be fine.. If it was a Chevy..... I would be nervous... J/K Chevy guys I was a gm tech for many years ;-)
