Jb Weld Didn't Work This Time :(
28 replies to this topic
#1 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,259 Thanks
  • 4,510 posts
Posted October 04, 2014 - 09:36 AM
Off to town to buy a new radiator :( . This one has a 1" split in the top, thought I could clean the area, lightly sanded the area, wiped off and applied 2 coats of JB. Let sit 24 hours. Still leaking.
  • Bud said thank you
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted October 04, 2014 - 09:39 AM
Note to self: Doesn't work as well on aluminum.
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,862 Thanks
  • 10,041 posts
Posted October 04, 2014 - 09:40 AM
Apparently it didn't work on the leak in your avatar either.
  • Gtractor, MH81, KennyP and 3 others have said thanks
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 04, 2014 - 09:47 AM
Just went through the same thing on the Benz..it is a composite plastic of some sort..I tried JB and epoxy ...like you..ended up buying a new radiator.
#5 TAHOE OFFLINE
TAHOE
  • 8,167 Thanks
  • 5,759 posts
Posted October 04, 2014 - 09:59 AM
Yea, I have tried JB weld on radiators and it's failed every time. Either doesn't stick well or can't take the heat and pressure.
  • Cvans said thank you
#6 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted October 04, 2014 - 10:12 AM
Expansion may be the culprit here...  J B doe's not expand...
  • Cvans and Bill 76 have said thanks
#7 Jazz OFFLINE
Jazz
  • 2,586 Thanks
  • 1,519 posts
Posted October 04, 2014 - 10:16 AM
There are various products on the market specifically for repair plastic rads and gas tanks. Maybe someone here has can recommend one. I have not used them myself as I don't own anything so modern as to have a plastic rad.   We had considered using this product for my sons truck but he opted for a new rad as he was heading cross country and was skeptical of the product.
http://www.ebay.com/...e_Tools&vxp=mtr
Edited by Jazz, October 04, 2014 - 10:18 AM.
  • Alc and Cvans have said thanks
#8 Alc ONLINE
  • 7,124 Thanks
  • 7,530 posts
Posted October 04, 2014 - 10:52 AM
I had luck using a cheap HF plastic welder on my dauthers friends plastic radiator , lookes like a soldering iron
Edited by Alc, October 04, 2014 - 10:52 AM.
  • GTTinkerer and Cvans have said thanks
#9 Texas Deere and Horse ONLINE
  • 14,862 Thanks
  • 15,511 posts
Posted October 04, 2014 - 01:14 PM
My local radiator shop replaces the tanks on those aluminum radiators all the time with great success and is a lot cheaper then buying a new one.
#10 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted October 04, 2014 - 02:16 PM
I checked into that once here. It would cost as much if not more than a new radiator.
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,259 Thanks
  • 4,510 posts
Posted October 04, 2014 - 05:00 PM
Less than $80.00 at Advanced Auto, including a gallon of antifreeze. The old cap was rated at 13psi, can anyone tell me what the new cap is in psi? looks like 1.1.
#12 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted October 04, 2014 - 05:20 PM
I can't read much on that cap!
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,259 Thanks
  • 4,510 posts
Posted October 04, 2014 - 05:25 PM
If I click it I can read it. Try this.... If it doesn't work I'll let you borrow my glasses.
#14 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted October 04, 2014 - 05:52 PM
I can read the first 2 lines! After that, I haven't a clue! I checked PSI to KPa, that didn't work!
#15 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted October 04, 2014 - 06:04 PM
I bet the Chinese translates to 1.1 bars - about 16PSI.
edit:
Actually, the Chinese looks like "danger"  = 危险
(based on google translate)
Edited by motobreeder, October 04, 2014 - 06:15 PM.
