i've got a thread on the other forum as well but might get better results here? long story short i'm doing a honda gx620 re-power in the 1886-05. i'm ready for wiring and need some help as i'm not too versed in small engine electrics. i have the honda control box hooked up now just to see what does what and to make sure it turned over and such. want to hook everything into the existing bolens wiring so i can use lights, ignition switch and charge battery and eliminate that honda control box. in the control box i have all the wires hooked up with the exception of the fuel cut solenoid because there is no wire in there for me to hook it to but it needs to be hooked up so it will get fuel to run.
here is the honda diagram......
here is the bolens diagram....
