Kohler K301 Broken Engine Head Cooling Fins
7 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted October 03, 2014 - 08:10 PM
How should I fix this? Should I fix it? Thanks.
#2 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted October 03, 2014 - 08:13 PM
It looks like it's been fixed before, but at least one is starting to come loose.
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 03, 2014 - 08:26 PM
I wouldnt worry about it...
  • WNYTractorTinkerer and Gabriel have said thanks
#4 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 03, 2014 - 09:22 PM
I doubt it will effect it that much or you could go this route if you want http://www.ebay.com/...=item2ed758dce8
  • Gabriel said thank you
#5 farmerall ONLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted October 03, 2014 - 09:31 PM
I wouldn't worry about it either. If it really bothers you I'd just replace the whole head.
#6 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted October 04, 2014 - 10:08 AM
I wouldn't be bothered with it. I would be more concerned with the paint on the head than the broken fins. It shouldn't be visible underneath the tin work.
  • Alc and Gabriel have said thanks
#7 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted October 04, 2014 - 12:41 PM
Do you mean that the head shouldn't have any paint on it?
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,458 Thanks
  • 5,765 posts
Posted October 04, 2014 - 12:56 PM
Not if the head is covered up.  The paint will work against the heat dissipation of the air cooling..  It will discolor or even burn in the valve area quickly unless the paint is high temperature..  If it's a show tractor that will only be started/ran short periods then the paint is OK..
  • Trav1s and Gabriel have said thanks
