B&s 18Hp
24 replies to this topic
#16 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 16, 2014 - 01:59 PM
You need to buy the whole coil pack, the wires are not replacable. I assume the wires were pulled out instead of a "no-spark" condition, in which the coil may not be bad. Many times a bad ignition switch, or safety switch will prevent spark.
Ok thank you, also i will have to check all of the wiring. I have a red on and off switch on the dash that im not sure what is for but im thinking head lights, and also there is a toggle switch on the dash that i believe is a kill switch. thank you i will have to order one. and find out what all the switches on the dash are for
#17 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted October 16, 2014 - 06:35 PM
The Red switch is for the lights, and the toggle is for the PTO, You really need to download and read the 'Operator Manual"
  • Auburn David said thank you
#18 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 16, 2014 - 06:54 PM
Did you check to see of you have a spark BEFORE you replace the coil?
#19 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted October 16, 2014 - 07:59 PM
Look under the seat and post the 917.XXXXX number and I am sure we can find you a Owners manual.
#20 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 16, 2014 - 08:04 PM
I have bought new park plugs and tested them and there was no spark i have not replaced the coil yet
Edited by Boots02, October 16, 2014 - 08:04 PM.
#21 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted October 16, 2014 - 08:09 PM
Have you traced out the wires using the diagram in the owners manual, and checked all the switches?
Plugs -> Coil pack -> Ignition Switch -> Neutral Safety -> PTO Safety -> Seat Switch,  will all cause a no-spark.
Edited by larrybl, October 16, 2014 - 08:12 PM.
  • Boots02 said thank you
#22 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 16, 2014 - 08:15 PM
yes i have and thank you thats exactly what i needed and i will have to find that number under the seat. hopefully i dont have a gas problem also!
#23 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted October 16, 2014 - 08:21 PM
That number will help greatly, then we can do this -> https://www.youtube....-tLIZkrLxjJEtbA
#24 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 17, 2014 - 10:05 AM
my model number is 917.255910
#25 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted October 17, 2014 - 08:15 PM
This is the same as my Hulk II. here is the diagram and the Owners manual.
