B&s 18Hp
24 replies to this topic
#1 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 01, 2014 - 04:55 PM
Hello everyone i am in need of some help. I recently purchased a craftsman II with the B&S 18 hp motor. When i got it it would not run. So i put in a new battery and it would crank but wouldnt start. It has oil and i put a little gas in the tank. Still wouldnt start. So i pulled the spark plugs and the were bone dry. I tested them and they were no good. So i will replace them tomorrow and possibly the spark plug wires. So my question is why are the spark plugs dry? the fuel lines are not clogged or anything and the tiny fuel filter on the fuel line coming out of the tank is clean. why am i not getting any gas?
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 01, 2014 - 05:10 PM
Probably has a fuel pump on that engine...or the the needle valve in the carb could be sticking..just a couple of things to check.
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 01, 2014 - 05:14 PM
Hard to say without knowing the type engine you have.
#4 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Several things come to mind:
Possibly you may not have cranked it long enough to fill the fuel lines, fuel pump and the fuel bowl in the carb.
The fuel lines may have deteriorated to the point the pump may be just sucking air.
The fuel pump may not be working.  It is normally on the metal "firewall" between the engine and the dash.  The impulse hose from the block to the fuel pump may be blocked or deteriorated causing the pump not to work or the diaphragms in the fuel pump may have hardened.  Fuel pump could also be built into the carb.
The float in the carb may not be opening the fuel inlet in the carb.
The jets in the carb may be plugged with debris or water.
Edited by GTTinkerer, October 01, 2014 - 05:18 PM.
#5 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted October 01, 2014 - 05:17 PM
Should be a B&S horizontal shaft opposed twin.  Great engine that really sounds good if it has the dual mufflers.
  • superaben said thank you
#6 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 01, 2014 - 05:20 PM
Thank you very much i will have to check all of that tomorrow, i got fed up today lol. Also where is the carb located at? i took the entire back half of the tractor apart and some of th engine apart but i cant seem to see the carb at all maybe im just blind haha
#7 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 01, 2014 - 05:21 PM
Thats the one. i plan on putting dual stacks on it
#8 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted October 01, 2014 - 06:19 PM
Hope this helps.
  • Auburn David and Boots02 have said thanks
#9 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 01, 2014 - 07:02 PM
Hope this helps.
Thank you very much that's what I needed
  • Auburn David said thank you
#10 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 01, 2014 - 08:32 PM
maybe a switch somewhere on carb that stopps fuel flow if theres now like weight on seat
#11 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted October 01, 2014 - 09:42 PM
Fuel isses are pretty common if the machine has sat for some time.  Listen to Bill's suggestions.
Its too old to have a shutoff "anti backfire" solenoid I believe.  But you might be right.  Those things are notorious for sticking after sitting, too.
Ben W.
#12 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,994 Thanks
  • 4,411 posts
Posted October 01, 2014 - 10:10 PM
Not adding much, but the stacks will require cutting the hood, or running without it. And try adding more gas to the tank, the pulse pump is kinda weak and requires some cranking to get fuel to flow. Not too much 5 sec with a 2 min starter cool down.
https://www.youtube....-tLIZkrLxjJEtbA
#13 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,462 Thanks
  • 5,768 posts
Posted October 02, 2014 - 08:07 AM
The Hulk looks nice with the pipes Larry!
Pull the air filter off and give it a prime with gas to see if it will start and run a bit..  May be enough to get the pulse fuel pump to get things moving..  Just a thought..
  • drbish said thank you
#14 Boots02 OFFLINE
Boots02
  • 4 Thanks
  • 19 posts
Posted October 16, 2014 - 01:23 PM
ok guys i still cant get it running so i tore it down to where the spark plug wires come out of the ignition coil? is that right? can i replace just the wires or do i need to buy the entire ignition coil and it would come with wires?
#15 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,994 Thanks
  • 4,411 posts
Posted October 16, 2014 - 01:54 PM
You need to buy the whole coil pack, the wires are not replacable. I assume the wires were pulled out instead of a "no-spark" condition, in which the coil may not be bad. Many times a bad ignition switch, or safety switch will prevent spark.
