What Is This For?
9 replies to this topic
#1 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted September 30, 2014 - 08:42 PM
Here's a pic.
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,348 Thanks
  • 4,961 posts
Posted September 30, 2014 - 09:10 PM
Looks like a travel stop or it probably is to hold that pin in place.  ???
I see its not really in line with the pin but if it goes in far enough it could sit in a groove in that pin therefore holding it from sideways movement.
Just a guess - I'm not sure what part of the machine I'm looking at.  :wave:
Edited by Gtractor, September 30, 2014 - 09:14 PM.
  • Gabriel said thank you
#3 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted September 30, 2014 - 09:15 PM
It looks like it sits to low to be able to have anything to do with the pin, but maybe I'm wrong.
#4 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,348 Thanks
  • 4,961 posts
Posted September 30, 2014 - 09:18 PM
I agree but if the pin had a dimple for the set screw to "hit" in a blind hole like that it would be very hard to line the dimple up with the set screw.  This way all the pin has to be is flush on both ends and the set screw will automatically line up.
Again,  just guessing......
Edited by Gtractor, September 30, 2014 - 09:19 PM.
#5 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted September 30, 2014 - 09:27 PM
Cub Cadet internal brake adjustment????
  • Gtractor and Gabriel have said thanks
#6 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted September 30, 2014 - 09:32 PM
Could be.
#7 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Not sure.
#8 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted September 30, 2014 - 10:58 PM
100% positive it's the adjustment for the internal brakes. Download the service manual from this site and you shall see.
#9 diesel nut OFFLINE
diesel nut
  • 707 Thanks
  • 428 posts
Posted September 30, 2014 - 11:02 PM
case442 and Kyocum are right. Adjustment screw for the internal brakes.  If you try to move it make sure its free before really reefing
on it. Had a customer at work bring one in cause he broke the screw and the cracked the arm trying to get the broken part out.  Hope this helps.             Stewart
#10 Cub 1650 OFFLINE
Cub 1650
  • 183 Thanks
  • 108 posts
Posted October 01, 2014 - 06:33 AM
It is definitely the cub cadet internal brake adjustment. I have A cub cadet 1650 with the internal break and that's exactly how mine looks.
