Got My Agco Allis Back Together
3 replies to this topic
#1 farmerall OFFLINE
  • 2,204 Thanks
  • 1,474 posts
Posted September 30, 2014 - 07:44 PM
A few months ago I bought this Agco Allis 918H from fellow member Mike aka Case442. When I bought the tractor the engine would run but only with full choke. After running for a few minutes and warming up the engine would bog down and stall. Mike had told me that the tractor had sat for 10+ years so I knew it was running bad due to a dirty carb.
First I tried to take the carb apart to clean the inside but two of the bowl bolts stripped so I couldn't get them out. Discouraged I tried a few different tricks in an attempt to clear what ever the blockage was. They didn't work.
Since I couldn't get the bolts out and had nothing to lose I decided to drill out the bolt heads. Of course after I drilled through the bolt heads the bolts turned out by hand. The inside of the of the carb was nasty. There was a lot of chunks of what was left over from the old gas drying up. To be honest I'm surprised the engine even ran at all. I got lucky and was able to replace the bowl bolts with two that came from an Onan carb.
After getting everything back together, the engine runs like new. Now I just need to get a deck drive belt and I'll be set for next year.
  • olcowhand, Alc, KennyP and 5 others have said thanks
#2 case442 OFFLINE
  • 694 Thanks
  • 424 posts
Posted September 30, 2014 - 08:05 PM
Hi Matt,
Glad too hear you got it running good. That should be a great tractor for you.
Take care,
  • farmerall and Gabriel have said thanks
#3 Talntedmrgreen OFFLINE
  • 3,274 Thanks
  • 2,309 posts
Posted October 02, 2014 - 01:42 PM
Nice work! That machine is one of the best out there...the result of 30 years of making what works, better and better.
  • farmerall said thank you
#4 KennyP ONLINE
  • 39,079 Thanks
  • 46,293 posts
Posted October 02, 2014 - 04:02 PM
Glad you could make it purr along again! Have fun with it!
