Wanting A Old Gt But What?
72 replies to this topic
#1 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 01:53 PM
I am wanting to get an older GT tractor but I am not really sure what. I am going to want to put a tiller on the back definitely a snow blower and plow for the front if I could find something that would lift a bucket would be nice and obviously have a three point hitch now here's my question to all what is the best tractor for my money and still being able to find Parts and atachments. this will be my first older gt and i do intend on using it for landscaping and planting some along with moving a lot of snow it will probably actually move way more snow than it will be doing eny thing else what is a good tractor for my needs
  • LilysDad, A.C.T., Sawdust and 2 others have said thanks
#2 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted September 30, 2014 - 02:11 PM
Cub Cadet, John Deere, and Wheel Horse are probably the most popular of the older GTs. Parts (new and used), as well as attachments (though all or most will be used), are more plentiful and still available for these brands.
Edited by Gabriel, September 30, 2014 - 08:16 PM.
  • Trav1s, Sawdust, icecream4070 and 1 other said thanks
#3 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 02:14 PM
What about the Bolin or mf
  • Trav1s and Gabriel have said thanks
#4 olcowhand ONLINE
  • 41,222 Thanks
  • 31,437 posts
Posted September 30, 2014 - 03:02 PM
If wanting a rear tiller, I'd get a tractor with 3pt lift and 2,000rpm rear pto & appropriate tiller.  Brand isn't as important as condition except you want a brand you can easily find parts used or new for.  A RED tractor is a good choice!  :smilewink:
  • superaben, Sawdust, Gabriel and 1 other said thanks
#5 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 04:13 PM
Ok thank you
  • A.C.T., Gabriel and propane1 have said thanks
#6 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted September 30, 2014 - 05:27 PM
LGT 165 Ford, will do all the things you mentioned.  Noel
  • icecream4070, FilledTires, Gabriel and 1 other said thanks
#7 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 05:56 PM
But it's a Ford lol
  • Trav1s, TAHOE, Sawdust and 2 others have said thanks
#8 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,324 Thanks
  • 9,790 posts
That's like asking which car should I buy. As you can see from the answers, there are a lot of different opinions and some of it is personal taste. The tractors listed so far are good. Some folks will add Simplicity.  As for the tiller, Wheel Horse doesn't have 3 pt hitch or rear pto and they work fine. Another determining factor is what brands are locally available. What state do you live in?
Edited by LilysDad, September 30, 2014 - 05:58 PM.
  • Gabriel and Ron Dziedzic have said thanks
#9 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted September 30, 2014 - 06:02 PM
You could add Sears to the mix if you don't mind using either a three point tiller with it's own engine (RotoSpade) or a tow behind with it's own engine.
#10 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 07:26 PM
Ok I live in upper michigan
  • Gabriel said thank you
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,976 Thanks
  • 10,004 posts
Posted September 30, 2014 - 07:31 PM
You're close to prime Case/Ingersoll hunting grounds. Keep an eye peeled for one of those, too.
If you see an ad and you have a question, just do a search or call MH81. (Alan) I'll pm his work and private cell #'s to you. He's a full of     info.
  • MH81, Trav1s, Gabriel and 1 other said thanks
#12 wilberj OFFLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted September 30, 2014 - 07:36 PM
You must mean Bolens. :D
Tube frames will do what most need done and there is alot of them around.
  • icecream4070, Gabriel and Ron Dziedzic have said thanks
#13 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted September 30, 2014 - 07:45 PM
Cub cadet has a lot of old er gts that have lots of interchangeable parts they have tillers plows etc pulse super ease to work on. Cubs use a shaft drive on most all the older models. They are a heavy built tractor lot of cast grill,axel,trans axel. And brinly still makes plows, snow plows although I don't know if the make them for the older ones anymore cultivators, fertilizer spreaders the list goes on.
Just my 2cents
Ther are lots and lots of great brands of gts out there and it's going to be hard for us to help you because of this. If I was you I would get on Craig's list and do a search for gts find out what looks good to you research it and then possibly buy
My opinion would be a cub cadet model only because of the parts availability the parts interchange like I said above.
Good luck on your search and show us picks when you find something.........
#14 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 07:47 PM
Is that ford gas or diesel?
#15 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 30, 2014 - 07:51 PM
So far I am thinking I would like to find a bolins, mf, or a cub
