Question About Compression.
7 replies to this topic
#1 HDWildBill OFFLINE
  • 8,975 Thanks
Posted September 30, 2014 - 01:44 PM
I have a little 27cc leaf blower in the shop that won't start.  It is getting fuel and spark but has very low compression between 45 & just barely 50 psi. I know the compression needs to be 90 or better for it to have power. When I try to start it I get nothing, not a pop not a grown nothing.
So my question is even with low compression shouldn't I at least get a pop or something even with low compression?
#2 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted September 30, 2014 - 07:05 PM
What brand is the blower?
Ben W.
  • HDWildBill said thank you
#3 Alc OFFLINE
  • 6,885 Thanks
  • 7,460 posts
Posted September 30, 2014 - 07:42 PM
Bill , not sure at what psi you need , (I think I asked that some time ago )  could you try a little motor oil to seal the rings andsee if it starts?
  • HDWildBill and propane1 have said thanks
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,463 Thanks
  • 5,768 posts
Posted September 30, 2014 - 07:54 PM
Howdy Bill..  2-strokes need higher compression to start than 50# for sure.  Try this-  Remove the Muffler and evaluate the piston and cylinder..  Look for scoring or aluminum deposits..  If there is some you are done.  If you are emotionally attached to the thing find a new block and R/B it.  OR-  Go spend about the same $$$ on another one..  If the bore looks OK then check for muffler blockage or blown C/S seals..  (lots of oil/dirt will be present in the area of the leak..
Good Luck!
  • Alc, sacsr, HDWildBill and 2 others have said thanks
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 01, 2014 - 09:45 AM
No there is no attachment to it.  It's a craftsman I'll check the cylinder through the exhaust port for any signs of scoring.  But even at  #50 shouldn't  do something like make a pop?  or some noise?
#6 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,463 Thanks
  • 5,768 posts
Posted October 01, 2014 - 01:58 PM
Put a little 2 cycle gas right into the carb throat and it should pop a bit but you better eat your Wheaties if you keep trying to get it started!   :wallbanging:
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 01, 2014 - 02:16 PM
Well I pulled the muffler and sure enough it has all kinds of scoring in not only the piston and rings but also the cylinder wall.  I have a friend who scraps metal so I'll give it to him.   I did try to pour some 2 stroke gas down the carb and still didn't get anything but at this point it really doesn't matter.  Thanks to everyone for their help. :thumbs:
  • Alc, WNYTractorTinkerer and Sawdust have said thanks
#8 Alc OFFLINE
  • 6,885 Thanks
  • 7,460 posts
Posted October 01, 2014 - 08:13 PM
Bill your not going to give up just because of a little scoring and maybe stuck rings are you ?
  • WNYTractorTinkerer and junkman have said thanks
