Suspension Setups
ford suspension
12 replies to this topic
#1 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted September 30, 2014 - 08:57 AM
Hello GTtalk,
I just purchased a '91 Ford YT 16H, but I have a question regarding the suspensions of older garden tractors in general.
It seems to me that there is a lot of wiggle/play in the suspension laterally. This is my first tractor, so I don't have a feel for how tight everything should be, say compared to a car.
#2 JDBrian OFFLINE
  • 9,592 Thanks
Posted September 30, 2014 - 10:25 AM
What do you mean by suspension? The rear axle should be solid and the front pivots in the middle. The front wheel bearings or axle bearings could be worn as well as the front axle pivot bushing. These should all be pretty tight but in many cases on older tractors they have been neglected and can be worn out.
#3 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted September 30, 2014 - 01:48 PM
Hey Brian,
You're right, the rear axle is solid and I don't see much issue there.
THe front axles seem very wobbly to me. For example, when the tractor is parked, I can shake it side to side a good 2-3 inches. I'll look at the front construction more carefully and I think changing bushings might be a good idea
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted September 30, 2014 - 03:16 PM
I am not familiar with the model Ford you have. But my JD 318 has bolt bumper stops that can be adjusted to take the forward/backward deflection out of the front axle. I need to back those out a bit myself and will next time I take the mower deck off for maintainence.
Edited by JD DANNELS, September 30, 2014 - 03:23 PM.
  • aevansgatech said thank you
#5 LilysDad ONLINE
LilysDad
    Crazy about GTTalk
  • 10,512 Thanks
  • 8,134 posts
Posted September 30, 2014 - 06:00 PM
Is there play in the steering wheel?
#6 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 01, 2014 - 07:06 AM
Yes, lots. I haven't spent the time to research that part yet. Any tips or common solutions for fixing the steering?
#7 Cat385B ONLINE
    Therapy CAT
  • 12,364 Thanks
  • 9,216 posts
Posted October 01, 2014 - 08:13 AM
Start at an end and work from there. It sounds to me like the front wheel bearings are shot. With the tractor parked, wheels straight, can you move the front tires side to side without rocking the tractor? If you jack up the front end, can you turn a wheel without moving the steering wheel?
#8 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 01, 2014 - 08:33 AM
I'll check tonight! Thanks Cat
#9 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 02, 2014 - 08:18 AM
So I did a quick test with the tractor on the ground. To my surprise, the wheels themselves will not rock back and forth. I can rock the tractor back and forth quite a bit, but not the wheels alone.
I'm going to jack up the front tonight and test the turning
#10 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 02, 2014 - 08:22 PM
Did this today. Yes, with the front end up in the air, I can freely turn the wheels side to side
What does this show?
#11 Cat385B ONLINE
    Therapy CAT
  • 12,364 Thanks
  • 9,216 posts
Posted October 02, 2014 - 09:17 PM
Check the linkages that control your steering. You must have worn or wallowed out parts, or wheel bearings that are shot.
#12 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 03, 2014 - 08:00 AM
If it was the wheel bearings, wouldn't the wheels be loose on the ground? I.e. I would've been able to rock the wheels themselves side to side if the bearings were shot?
I'll definitely need to look into the steering column and linkages
#13 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 03, 2014 - 12:25 PM
by the way, I also noticed it has grease fittings. It should be easy enough to get a gun and put new grease, but there is a lot of caked on grease all around the fittings.
Should I do my best to clean the fittings before putting more grease?
Is it necessary to disassemble further to clean everything out?
Also tagged with one or more of these keywords: ford, suspension
