Briggs And Stratton 18Hp Twin 2
7 replies to this topic
#1 thadscub OFFLINE
thadscub
  • 73 Thanks
  • 86 posts
Posted September 29, 2014 - 07:39 PM
hi guys i have a problem i think the starter is shot but before i spend money how di i test the starter and wiring
thanks thad
#2 dthomp17 ONLINE
dthomp17
  • 559 Thanks
  • 452 posts
Posted September 29, 2014 - 08:41 PM
Welcome to the forum, glad to have you.  There are several other things I would rule out before I would consider replacing the starter.  Do you get any sound at all when you try to start it?  If you're not getting anything, you  could have a bad ignition switch, a bad safety switch, a bad solenoid, or a bad ground connection and a perfectly good starter.  If you have a volt meter, you can check the starter ground to be sure it's making contact and you could also check your safety switches and ignition switch to be sure they're making contact.  You can turn the ignition switch to "start" and see if you're getting 12 volts to the starter.  If not, you've got a bad switch, solenoid, or connection somewhere.  Almost forgot, be sure you have a good fully charged battery.
  • superaben said thank you
#3 speedex99gt OFFLINE
speedex99gt
  • 43 Thanks
  • 52 posts
Posted September 29, 2014 - 09:31 PM
You can take a screw driver and cross the solenoid.
#4 thadscub OFFLINE
thadscub
  • 73 Thanks
  • 86 posts
Posted September 29, 2014 - 10:03 PM
how do i do that when i only have one terminal for the wire
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 9,456 Thanks
  • 5,259 posts
Posted September 29, 2014 - 10:09 PM
Check this video out..  Fire back with any questions
  • davidj927 said thank you
#6 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted September 30, 2014 - 05:06 AM
I know sometimes the bendix sticks in them
#7 KennyP ONLINE
  • 34,244 Thanks
  • 43,366 posts
Posted September 30, 2014 - 05:23 AM
This manual shows how to test the starter, starting page 86, section 6B.
I also merged these two threads!
Edited by KennyP, September 30, 2014 - 05:35 AM.
#8 speedex99gt OFFLINE
speedex99gt
  • 43 Thanks
  • 52 posts
Posted September 30, 2014 - 06:17 PM
Take a pair of jumper cables or battery charger take the ground and ground it and touch the positive to the terminal and the starter should spin .
