Yeah, I Guess It Smokes A Little
15 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted September 29, 2014 - 03:12 PM
One of our next school small engines projects.
  • MH81, Alc, Auburn David and 1 other said thanks
#2 olcowhand ONLINE
  • 41,126 Thanks
  • 31,411 posts
Posted September 29, 2014 - 03:23 PM
Maybe just a tad much on the smoke!  You sure someone didn't plumb the intake to the oil sump?
  • Auburn David said thank you
#3 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted September 29, 2014 - 03:26 PM
Pretty sure it's dumping it out the breather.
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 29, 2014 - 03:38 PM
Well that one isn't married..I can tell because it has no rings...
  • Tim Bergfeld said thank you
#5 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted September 29, 2014 - 03:39 PM
Hmmmmmmm? Might want to install a new plug when your done with it!
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 29, 2014 - 04:42 PM
Looks like a good test for Mmo
  • superaben said thank you
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,294 Thanks
  • 9,777 posts
Posted September 29, 2014 - 05:22 PM
Ummmm Hummmm! Kids getting high on fumes.
#8 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 29, 2014 - 05:54 PM
I'm not sure you could even buy enough MMO to fix that!
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 29, 2014 - 07:17 PM
It would make a good crop duster! Is there a lit barbecue under the hood?
#10 EricFromPa ONLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted September 29, 2014 - 07:51 PM
lol Another OHV Briggs engine with a Blown Head Gasket.
That one is blown pretty good.The gasket blows between the Cylinder and the Push Rod galley on those.There's only about 1/4 of metal between the 2.Did you guys have a hard time trying to get it to crank over?When the gasket blows it messes with the valve clearance a bit to.
They are an Easy fix.$16 head gasket and set the valve lash and it will be good as new.
  • jdslednut, sacsr and superaben have said thanks
#11 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 29, 2014 - 08:06 PM
Ok that's the best one I have heard yet
Tim
#12 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted September 29, 2014 - 08:33 PM
I think we may have a winner.  It does crank a little tough.
#13 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 29, 2014 - 08:57 PM
How are the mosquitoes up your way now?
Ben W.
#14 EricFromPa ONLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted September 29, 2014 - 08:59 PM
I've fixed a couple *hundred lol
I seem to get atleast a dozen every couple months.Not many 1st gen 14 and 14.5hp ones Most are 15 15.5 16.5 17.5 and the big 18.5 single.
I see lots of the 15.5hp and 17.5hp engines.They used those on most of the (MTD) Yard Machines and TroyBuilt machines.Poulan (AYP) used alot of the 16.5 and 18,18.5 engines on the tractors with bigger 48"-60" decks.
#15 junkman OFFLINE
junkman
  • 127 Thanks
  • 58 posts
Posted September 29, 2014 - 09:56 PM
Glad to see it is a easy fix. I got a 14hp Kohler that smoked really bad. Had wore more then 30 thousandths of the cylinder walls. I was surprised it even ran.
