Wanted
Ford Yt Fuel Cap / Gauge Assembly
ford yt 16h
14 replies to this topic
#1 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted September 29, 2014 - 02:19 PM
Looking for a non-broken gas cap (with gauge assembly) for a Ford YT 16H garden tractor
#2 EricFromPa OFFLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted September 29, 2014 - 08:41 PM
Ebay Ebay Ebay lol
Did some checking and it takes the 5" and 5 1/4" long float.
Cross reference numbers.
Ford/New Holland: LB740378
Cub Cadet: 109037-C1
Cub Cadet: 109037-C2
Murray: 024064MA
Murray 024064MA $16.00 free shipping
http://www.ebay.com/...=item1c21a476cf
Cub Cadet 109037-C1/C2 $21.00 free shipping
http://www.ebay.com/...=item3cd6f5f004
Ford/New Holland wants $94.56 + shipping for the darn thing.Wonder why when it's still used on many different machines.
Edited by EricFromPa, September 29, 2014 - 08:42 PM.
  • aevansgatech said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 29, 2014 - 08:56 PM
I figured out the cross reference the first time awhile back and I have sold quite a few of these gauges.  5 1/4 is a little short but it leaves a "reserve" in the tank just in case you decide to make that final pass around the yard even though the tank reads empty.
I sell them for $18.
Ben W.
#4 EricFromPa OFFLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted September 29, 2014 - 09:48 PM
The Ford/New Holland: part # LB740378 has the Optional In Dash mounted Electric fuel gauge hook up on it.That's why it's so darn expensive from New Holland.Some of the LawnBoy badged machines used the dash mounted gauge with a Low Fuel light on the bottom left corner.
My neighbor Matt has a LawnBoy badged 1.Sorta looked like this.The little Gas pump has a red light in it.
#5 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted September 30, 2014 - 12:18 AM
$95 for that--thats crazy.But if you need one I guess they have you bent over a barrel since their the only show in town.
#6 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted September 30, 2014 - 10:15 AM
Thanks everyone! Yeah, I saw the $95 price tag on the OEM Ford/NH one and almost choked!
Good to know it's a fairly common cross-brand part.
Ben, is this the one you sell? It shows $22 and out of stock..
http://oldpathsequip...740378-125-260/
#7 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 04, 2014 - 11:42 AM
Does anyone know the correct part # for the oil reservoir cap? Mine is cracked almost the whole way around. I ordered a $5 "oil cap" from searspartsdirect but it ended up being the wrong part
Here's the part I'm looking for
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 04, 2014 - 12:52 PM
Measure the cap diameter and post a pic of the threads/underside of the cap. Simplicity uses what looks to be the same one on their FC series. I own one, and will measure it when I get home tonight. Should be lots easier finding one off a Simplicity.
#9 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted October 04, 2014 - 03:53 PM
According to Ford/New Holland, the reservoir is part # LB744216 @ $67+/-. The cap is part # LB709948. Cap Gasket is # LB709949. No prices listed for the cap or gasket. I would say get hold of New Holland and see if the cap is available!
#10 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 04, 2014 - 07:25 PM
The cap is roughly 3 1/4" outside diameter and 3" inside diameter. The best I could guess was 1/16" between threads as well. Any idea what part might work as a substitute?
On the plus side, the gasket looks good, just the cap is cracked
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 04, 2014 - 08:30 PM
No dice on the Simplicity, it is 1/4" smaller.
#12 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 04, 2014 - 09:00 PM
Along with checking on Kenny's info, Eaton still uses the same size reservoir on their Eaton 700's.
#13 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 04, 2014 - 09:01 PM
Dang. I may have to just use an epoxy to seal it and sand it down
#14 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 04, 2014 - 11:06 PM
All the results for the LawnBoy part are showing cap not available :-(
#15 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 07, 2014 - 08:41 AM
New Fuel gauge installed!
Its a bit shorter than the original, but that's OK. It will just tell me I'm empty before I really am.
On the tractor
Also tagged with one or more of these keywords: wanted, ford, yt 16h
