Honda Idle Issues
honda idle mower
12 replies to this topic
#1 robdog09 OFFLINE
robdog09
  • 4 Thanks
  • 16 posts
Posted September 29, 2014 - 11:43 AM
See YT video below. My Honda power (which is great, btw), has this weird idle problem. When I get blade going, it runs fine, but when its idling, seems to have this problem.
If its nothing to worry about, thats great, but curious if this is evidence of a larger issue.
any thoughts?
(Sorry, dropped the phone for a second in the video)
#2 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,119 Thanks
  • 4,887 posts
Posted September 29, 2014 - 12:15 PM
It probably has a small piece of crud in the jet.  Those Honda carbs are tricky - the orifices in the carb are tiny and plug easily.  I'd run some Seafoam in the gas and see if it takes care of the blockage.
Footnote:
"Crud" is a very scientific term used to describe dirt, rust, grass, leaf, gasket material, or other foreign debris that can contaminate your fuel supply.  :wave:
Edited by Gtractor, September 29, 2014 - 12:26 PM.
  • Alc, superaben and Auburn David have said thanks
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 29, 2014 - 01:34 PM
Yep..trash in the carb.
#4 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 29, 2014 - 01:37 PM
Yup what they said
Tim
#5 robdog09 OFFLINE
robdog09
  • 4 Thanks
  • 16 posts
Posted September 29, 2014 - 04:19 PM
Great, easy fix. I just bought on amazon. Will let you know how it goes.
  • Auburn David said thank you
#6 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted September 29, 2014 - 04:54 PM
10.99 for a can will fix all your problems for a can of seafoam put some in the gas and dribble some in the carb till it smokes a bunch
Tim
#7 EricFromPa ONLINE
EricFromPa
  • 3,523 Thanks
  • 3,070 posts
Posted September 29, 2014 - 08:05 PM
Seafoam will clean Very little of the dirt out of the carb.More than likely you will have to take the carb off and Manually clean it and spray Carb cleaner through all of the Jets.
Still don't know why people use that stuff on small engines.2 small nuts to take the carb off and take the float bowl off and a $4 can of Carb cleaner is all you need.
Could have water laying in the bottom of the float bowl.Seafoam will not get rid of all the water.
Seafoam contains several different Oils,naphtha and isopropyl alcohol.
Edited by EricFromPa, September 29, 2014 - 08:20 PM.
  • HDWildBill said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 29, 2014 - 08:47 PM
New Honda carburetors are pretty cheap, too.  I usually have not cleaned a Honda carb in the past.  By the time I do that, it is just as simple to bolt on a nice new one and wave goodbye.
If you want a new one, let me know.
That should be in the glossary of GTTalk.  :thumbs: :thumbs:
Ben W.
  • Gtractor and HDWildBill have said thanks
#9 robdog09 OFFLINE
robdog09
  • 4 Thanks
  • 16 posts
Posted October 03, 2014 - 12:07 PM
If you have a site that I can buy a new carb for cheap, pls send it over. Ill try the Seafoam and see what happens, but agree i rather buy a new carb than repair an existing one. Been down that path with a power washer and taking it apart 10 times, with no fix. Ended up replacing the carb for $40 and it runs great.
#10 robdog09 OFFLINE
robdog09
  • 4 Thanks
  • 16 posts
Posted October 04, 2014 - 09:45 AM
That didn't seem to work. Dumped about 8 oz in the tank, ran it for a good 10-15 mins. It seemed to idle harder and higher, but still the same thing that is seen in the video i originally posted. Any other ideas?
maybe next step ill clean the carb, or if @superaben has that link for cheap carbs.
#11 robdog09 OFFLINE
robdog09
  • 4 Thanks
  • 16 posts
Posted October 14, 2014 - 08:14 AM
Took the carb apart, cleaned it, and show compressed air through all the holes and passages. Still no dice.
Any other ideas? Any chance a cracked gasket could be causing this? They looked pretty old.
#12 olcowhand OFFLINE
  • 40,365 Thanks
  • 31,175 posts
Posted October 14, 2014 - 08:16 AM
You may have a leaky gasket on the intake.
#13 robdog09 OFFLINE
robdog09
  • 4 Thanks
  • 16 posts
Posted October 19, 2014 - 06:34 PM
replaced the carb. Works great now!
