Balancing Rotary Cutter Blades
cutter blades
8 replies to this topic
#1 Thrash OFFLINE
Thrash
  • 9 Thanks
  • 4 posts
Posted September 29, 2014 - 10:44 AM
I would like to know if some of you guys out there balance your rotary cutter blades. Here is what I've come up with that does a good job and can still be used as a level.
  • massey driver, Alc, Bruce Dorsi and 1 other said thanks
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted September 29, 2014 - 10:52 AM
Welcome to GTtalk.  That looks like a nice solution.  Do you have some Pics using it?
#3 Thrash OFFLINE
Thrash
  • 9 Thanks
  • 4 posts
Posted September 29, 2014 - 11:00 AM
Well that is how it is used, just grind off the heavy one until they sit balanced, then they are ready to be put back on and it really helps take the vibration out and saves those gear boxes.
  • tinbender7, HDWildBill and boyscout862 have said thanks
#4 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted September 29, 2014 - 11:10 AM
Welcome to GTT. Relax and enjoy the site. Good Luck, Rick
#5 KennyP ONLINE
  • 40,995 Thanks
  • 47,159 posts
Posted September 29, 2014 - 03:36 PM
Looks like a viable solution!
#6 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted September 29, 2014 - 03:45 PM
Don't they come balanced from factory? ours did as did the replacements.
#7 Bolens 1000 ONLINE
  • 15,452 Thanks
  • 18,290 posts
Posted September 29, 2014 - 03:50 PM
Yes, they do come perfectly balanced when new but once you start hitting things and re-sharpening you need to check for balance.
  • HDWildBill and superaben have said thanks
#8 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted September 29, 2014 - 07:28 PM
you can also use a kitchen scale
only problem max is about 12 pounds
#9 Thrash OFFLINE
Thrash
  • 9 Thanks
  • 4 posts
I worked on a 8' bush hog for a fellow about 2 days ago, he had 2 sets of blades, one set was real close, the other set was about 3 oz out. It was shaking his hole tractor, after we put them back on, you could set a full glass of water on it and it would not spill. He wanted one.
  • KennyP and superaben have said thanks
