In Need Of New Rear Tires.
10 replies to this topic
#1 mike66 OFFLINE
mike66
  • 4 Thanks
  • 8 posts
Posted September 28, 2014 - 04:22 PM
I am in the need for some new rear tires, currently I have Carlisle Turf Master 24x1200-12 and checking the prices they seem to be running 100+ each. I use the tractor mainly for pulling a drag for clearing the grounds and I pull a little utility trailer about the property (No cutting deck installed) so maybe there is a better tire recommendation for my needs. Any recommendations would be appreciated.
Mike
  • 14,792 Thanks
  • 15,492 posts
Posted September 28, 2014 - 04:34 PM
What are you running them on, what size tractor?
#3 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted September 28, 2014 - 04:59 PM
That's definitely an odd size.
What was the size of the original tires on the tractor?
#4 mike66 OFFLINE
mike66
  • 4 Thanks
  • 8 posts
Posted September 28, 2014 - 07:04 PM
The garden tractor is a Craftman with a  24hp Kohler V-Twin and a 52" deck which I never used. These are the original tires and the rear are showing there age.
#5 mike66 OFFLINE
mike66
  • 4 Thanks
  • 8 posts
Posted September 28, 2014 - 07:05 PM
The original size was 24x12.00-12 just showing there age.
#6 olcowhand ONLINE
  • 41,026 Thanks
  • 31,379 posts
Posted September 28, 2014 - 07:08 PM
I had Those same 24" tires on my Allis 416 that Meangreen now has.  You might check with our site sponsor bhts to see if he can price those to you.
#7 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
OK, so what are you looking for?
Basically what you now have?
Something with maybe more traction like an Ag style tire?
Are you opposed to using a different tire size?
#8 BTS ONLINE
BTS
    Make Stuff Up
  • 4,239 Thanks
  • 2,450 posts
Posted September 28, 2014 - 07:49 PM
I have some 24-12-12 turf tires, lightly used, have a string or two in them but they are good tires. I have no need for them so I'll sell them cheap if your interested. I can send you pictures if you want.
Thanks
#9 mike66 OFFLINE
mike66
  • 4 Thanks
  • 8 posts
Posted September 28, 2014 - 08:59 PM
Would like something with more traction. I just drag my yard and pull a utility trailer about the property. When I drag the property sometimes the Turf Saver tires just spin so a more agressive tire may be what is needed. The Turf Saver tires I currently have work OK (Over 10 years in service) but I don't have any turf to mow and one of the tires no longer is holding air as the sidewall has a slit where it is leaking. Thx
#10 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted September 28, 2014 - 10:04 PM
This is a bit 'outside the box':
http://www.discountu...-UTV-ATV-TIRES/
Only problem is that they are 25x10-12 which would be 1" taller and 2" narrower than your current tires, but they WILL give you all the traction you would ever want.
I have those tires on 3 of my tractors and they are great.
#11 TAHOE ONLINE
TAHOE
  • 7,946 Thanks
  • 5,666 posts
Posted September 29, 2014 - 07:04 AM
Most guys will tell you to run some type of ag/bar lug tire. I have a Sears Subruban that does everything from mowing duties to plowing a garden to grading with a rear box blade and moving material with a front dump bucket. I have 23x10.50 Deestones and they are a decent all purpose tire. You may hear the ags will tear up your yard  and yes, if you start spinning they will dig, but in my opinion they hold traction alot longer than a pair of turfs like you have. When turfs spin, they tear up some grass in a hurry. I am much happier and have less damage when using my ags. Wheel weights and adding fluid inside tires helps with traction also.
In your case, I would also consider some Carlisle Field trax, but they are $$$$$$
Here are some possible tires for you.
http://www.greatercl...nda-K472/Detail
http://www.ebay.com/...0c4b4de&vxp=mtr
http://www.ebay.com/...=item43c6c612cc
These are ag tires, but the lugs are a little shorter and rounder shoulders. We use on our church Zero turn and they grip, but less damage when spinning around those tress.
http://www.ebay.com/...=item51bfd74cfd
