Starting Restoration Process Of Cub Cadet 104 .
164 replies to this topic
#46 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 10, 2014 - 11:38 PM
Do you paint your nuts and bolts before you put them on the tractor?
#47 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 11, 2014 - 05:05 AM
Yes, but I let them dry for at least three days for the paint to completely cure and harden . During the winter I let them dry longer, sometimes up to a week . I occasionally paint in-place but the required masking is time consuming . I originally tried powder coating each fastener head . It came out okay, but the real issue was that the bolt/screw head had grown so much that standard wrenches wouldn't fit them . Don't forget that the coating is two  layers thick . First is a layer of powder coat primer , followed by the final top/color coat . Since each technician applies the powder in different thickness , the final thickness can vary considerably ,
I slide washers, both plain and lock washers onto a square stick and primer and paint . You can vary the stick size to accommodate each washer's diameter . Don't use a round dowel as the paint will dry and the washers will be damned near impossible to get off . You get 100% contact with a round dowel , but only the four corners of the square stick contact the inside edge of each washer ( or nut ) . Then make sure that the inside of the wrench/socket is clean and they will tighten with out getting too marred . I use nylon locknuts whenever necessary and in fact all hardware is stainless except for those marked IH on the head . Once painted no one can tell the difference  , but the rust problem is reduced . I try to buy my stainless hardware by the box as the price is cheaper in quantity .
Ask a simple question and you get a thirty minute lecture ! Just passing on my way of doing things . What ever way you use is the right way for you and that's okay . Have a great day .
mike912e
  • KennyP, Sawdust and Gabriel have said thanks
#48 KennyP ONLINE
  • 37,425 Thanks
  • 45,463 posts
Posted November 11, 2014 - 06:01 AM
That Kohler looks great! Thanks for the info on doing the hardware. I have some stiff foam I stick the bolts into to do the heads. Just leave a little space between the head and the foam so they don't stick down.
  • mike912e and Gabriel have said thanks
#49 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 11, 2014 - 07:03 AM
KennyP,
   Thanks for the tip . I have used a sheet of cardboard with "X" slots cut into it to hold the fastener's being painted . To powdercoat the fastener heads I drilled and tapped a 1/4" thick piece of aluminum sheet to hold them during the process of baking the powder coating ( 350-400 degrees Fahrenheit ) . I had to drill and tap 1/4" , 5/16" , 3/8" and a few of the oddball sizes as well . What we do for our hobby !
mike912e
  • Alc, KennyP and BNK have said thanks
#50 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 11, 2014 - 09:24 AM
mike912e
Thanks!
#51 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 11, 2014 - 07:57 PM
Here's today's results . Mounted the PTO and pulley on the front of the engine . Installed the throttle and choke brackets below the carburetor . Hooked the throttle linkage from the governor arm to the throttle arm on the carburetor . Installed the four wheels . Added the battery hold-down clamp, throttle control and implement arm stop, key switch, hood hold-downs latches . Finally figured out how to get better close-up pictures and have provided a couple . Enjoy ! Tomorrow's goal is to get the engine mounted in the frame .
  • Alc, GTpicker01, Gabriel and 1 other said thanks
#52 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 12, 2014 - 09:29 AM
Looking good! Thanks for the pictures and update! Keep them coming!
  • mike912e said thank you
#53 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 12, 2014 - 04:53 PM
Engine installed and tractor back up on the lift . Now to start adding all the peripherals like muffler , choke and throttle cables , air cleaner . gas tank , etc . I won't be getting much done on the tractor for the next few days as I will be concentrating on the fiberglass dash panel restoration . Then the steering column will get installed followed by the remaining decals . Won't be long until she's up and running again !
  • Alc, Sawdust, GTpicker01 and 2 others have said thanks
#54 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 13, 2014 - 05:35 PM
Started the repair on the fiberglass dash panel today . Filled the area that was worn through and another area that was chipped off . The pictures show the repairs after filling with glass fibers and epoxy and after the first coat of primer . I'll let it dry overnight and sand and top coat it tomorrow .
  • Alc, Sawdust, GTpicker01 and 1 other said thanks
#55 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 13, 2014 - 09:19 PM
Your dash looks nice!
#56 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 14, 2014 - 03:06 PM
Got the primer sanded and the gloss white paint on today . I'll let it dry for at least a day in the nice warn, dry house then sand it out with 3500 grit wet/dry sandpaper . Then for the decals and installation on the metal dash support . In the meantime I'll take the screws that hold the dash to the metal support to my buffing wheel and make them look like chrome .
  • Sawdust and Gabriel have said thanks
#57 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 14, 2014 - 08:00 PM
Very nice! What kind of epoxy did you use?
#58 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted November 14, 2014 - 10:40 PM
Gabriel,
   I've been building and flying radio controlled model airplanes for fifty years so I had this available . It can be purchased at any local hobby shop or you might try online sources as well . I was concerned that the dash was polyester material which epoxy won't adhere to very well, if not at all sometimes . As it turned out the dash material is epoxy and the repair turned out just fine . Here's a picture of the containers of epoxy that I used : The company's name is Bob Smith Industries ( BSI ) . The work time is fifteen minutes with a total cure time of three hours . Then it can be sanded and painted . Instructions are on the label .
#59 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted November 14, 2014 - 11:20 PM
Finally got caught up & have enjoyed every word & pic. Not much to say that hasn't already been said but  :worship:
#60 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted November 15, 2014 - 06:47 AM
I have restored a few tractors in my time but your work has put my resto's to shame. Outstanding attention to detail to include the ID tags,rivets & grease fittings. Major learning process for me with the powder coating as well. I assume this unit will be a feature story in Cadet Connection magazine in the future? I will be following this thread for sure. What a way to enjoy retirement!
