Buying A '91 Ford Yt 16H!
33 replies to this topic
#16 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 05, 2014 - 12:32 PM
Refinished the airbox cover and flange by sanding off all surface rust, using Rust Reformer, and re-painting in black
Ford's first job: remove our old cracked mailbox post. It struggled, but just had enough power for the job
Edited by aevansgatech, October 05, 2014 - 12:33 PM.
  • KennyP, tinbender7 and Gabriel have said thanks
#17 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 13, 2014 - 08:09 AM
Installed new spark plugs, a new fuel filter, and fuel line this weekend. Also sanded down and refinished most of the metal surrounding the engine
She's looking good! :thumbs:
  • Gabriel said thank you
#18 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 13, 2014 - 08:10 AM
Spark plugs made a big difference in how quickly it starts and how 'strong' the engine feels. Definitely smoother operation all around :firejumper:
  • KennyP and T Guiles have said thanks
#19 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted November 06, 2014 - 01:21 AM
I'm sure it's been said but get your self some wheel weights and chains for plowing snow, or you could load the tires. I enjoy plowing with my ford and am amazed how much snow it pushes. I have a 81 and 83 lgt 165. BE VERY CAREFUL..... this is an addiction and it starts by buying one gt then you have seven around the house  :smilewink:
#20 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 06, 2014 - 08:09 AM
Where did you find your wheel weights? Are there other brands that will fit?
#21 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 19, 2014 - 10:43 PM
Today was nothing compared to some parts of the country, but I sure had fun pushing snow!
View My Video
#22 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted November 29, 2014 - 11:26 AM
Are you still in need of a cap for your hydro fluid reservoir? Here's a link that might help:
http://www.usplastic...parentcatid=838
I thought you might be able to replace your reservoir with one of these tanks. They offer some caps, but I'm not sure if they would work on your reservoir or not. I thought it might be easier to replace the whole tank and cap (you could buy a new tank and add a cap that was meant for it), than to try and find a cap for your tank. I'm not sure if these tanks are meant for oil though. Just a thought.
Edited by Gabriel, November 29, 2014 - 11:31 AM.
#23 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted November 29, 2014 - 11:36 AM
They also offer fittings that might be of help (to make the tank as close as possible in function to the original one), should you decide to make one of their tanks work (if you would even need any).
Edited by Gabriel, November 29, 2014 - 11:39 AM.
#24 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted December 01, 2014 - 03:37 PM
Thanks for the link, Gabriel. Unfortunately, it looks like the caps themselves are either too big or too small. Indeed, it would require putting a new complete reservoir in. I think I'll try to fix the cap or luck into one first, then consider a reservoir swap if needed.
.. stupid question:.. the hydro trans reservoir doesn't pressurize at all does it? I've been using it with the cracked cap and haven't noticed any real issue in doing so.
#25 KennyP ONLINE
  • 40,837 Thanks
  • 47,077 posts
Posted December 01, 2014 - 04:00 PM
Have you tried New Holland for this cap? I found one at Messicks.
Or is it this one?
#26 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted December 02, 2014 - 09:00 AM
Looks like it could be the one.. but Merrick's shows 0 available stock
#27 KennyP ONLINE
  • 40,837 Thanks
  • 47,077 posts
Posted December 02, 2014 - 09:13 AM
You can always call them to see. I have had them search dealers to find parts for me! Someone may have one on a shelf somewhere!
#28 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted December 02, 2014 - 10:56 AM
I don't think so. I think the reservoir is only for oil expansion.
#29 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted December 02, 2014 - 11:06 AM
I found some places that have the correct cap!! Here's a link: http://www.tractorho...artnum=ET103530
#30 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted December 02, 2014 - 11:10 AM
Is ET103530 the correct part number? That's what I put in to find those results (at TractorHouse.com).
