Wanted
Minneapolis Moline 114 Hydro
for free electrical parts knobs
26 replies to this topic
#16 Hopehill OFFLINE
Hopehill
  • 11 Thanks
  • 10 posts
Posted September 27, 2014 - 07:31 AM
Welcome to GTTalk !     Very nice job you did . Did your fil own it for a long time ?
I'm not having much luck finding a diagram. Only the pic in the parts manual for a Jake with the electric lift and that leaves a lot to be desired.
If I remember, I can get a pic from my Jake 1450 of the back side of the dash for you. It is an electric lift tractor.
Thanks any help Is appreciated.
#17 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted September 27, 2014 - 07:54 AM
I'm looking for a electric lift for the Jake. I have the motor that works, but the PO lost the rest of it.
#18 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted September 27, 2014 - 09:05 AM
Here's a few shots from my Jake 1450. Looking this over, I may be able to make a diagram up. Just take a little time tracing wires.
I tried to get a closeup of the back side of the lift switch. Just looks like a DPDT switch to me.
I can trace those wires for you if need be.
  • Hopehill said thank you
#19 Hopehill OFFLINE
Hopehill
  • 11 Thanks
  • 10 posts
Posted September 28, 2014 - 07:44 AM
Kenny that is great.   Looks just like the set up we have.  I actually do have the deck lift working but one of the connections on the back is broken and I have basically glued it back on.  seems to be holding but may need to replace it.  I don't  have the headlight switch & pto working.  Painter tried to wire it up but I ended up unwrapping all of harness to try and figure it out.  Found wires not connected to anything and I know that may be the case for 1 or 2 wires but still can't get the pto and lights to work via the switches.  Any chance you could get me a close up on the pto switch and are both wires on the headlight switch connected to something.  I have 1 that was left unconnected for some reason.   Headlights do work when power is supplied but not able to get them to work with the switch (might be bad switch I guess)
thanks so much for taking the time to help me out.
#20 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted September 28, 2014 - 08:44 AM
I traced out the Lift switch wires for you (and others if need be). Made a little drawing for you. Line colors are wires colors.
If you need more, I can use the Jake to figure things out.
  • olcowhand and Hopehill have said thanks
#21 Hopehill OFFLINE
Hopehill
  • 11 Thanks
  • 10 posts
Posted September 29, 2014 - 12:45 PM
Kenny that's perfect. Any chance you could trace the pto wires from the switch like that too?
#22 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted September 29, 2014 - 03:33 PM
Probably!
#23 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted October 01, 2014 - 07:04 AM
I'll see what I can do in the next couple days (rain coming).  By Sunday for sure!
#24 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted October 02, 2014 - 05:57 AM
Here is how my PTO is wired. The Lift power wire is attached to the switch also.
#25 Hopehill OFFLINE
Hopehill
  • 11 Thanks
  • 10 posts
Posted October 08, 2014 - 07:13 AM
Perfect.  thanks for doing this for me.   I will take this diagram and see what I can do with it this weekend.  I will let you know how it all works out.
#26 Hopehill OFFLINE
Hopehill
  • 11 Thanks
  • 10 posts
Posted October 29, 2014 - 07:29 AM
Kenny. Thanks again for the taking the time to get those wiring diagrams and pictures for me. I was able to get everything working on this machine and I really do appreciate it. It really made my father in law happy too to see it finished as well.
Thanks again.
John
#27 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted October 29, 2014 - 07:48 AM
Thanks again.
John
Glad I could help you out! There just isn't a lot out there on these MM's. It was just a whim that made me think of the Jake sitting there with the same options. Glad you got it all working!
Also tagged with one or more of these keywords: Wanted, for free, electrical parts, knobs
