Old Page Tractor Restoration
6 replies to this topic
#1 gamefarmone OFFLINE
gamefarmone
  • 2 Thanks
  • 8 posts
Posted September 24, 2014 - 07:54 PM
I'm beginning a restore on an old Page garden tractor - one that has been left out for years by the previous owner.
  In draining all the fluids I noticed pretty good leaks in the rear wheel seals, and after cleaning the hubs off, found out that the "seals" look like nothing but some kind of oakum/fiber packed in around the axles.
  Does anybody know if just repacking with oakum will work, or is it more likely they are packed with something else?
  I know that some of the older Massey's (and some Fords, too, I think) used some kind of rope for a rear main seal.
  Any advice or info?
        Thanks,
        gamefarmone
  • panzersarebest said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted September 24, 2014 - 08:44 PM
Welcome to the forum, neighbor.  Whereabouts in SW VA are you?
The rope seals were even used on engine seals.  I can get some sizes, but its hit and miss.
This guy has some info on them, I've had this link in my reference file:
http://nailheadbuick...-seal-correctly
Ben W.
  • Bill56 and Gtractor have said thanks
#3 Alc ONLINE
  • 7,357 Thanks
  • 7,638 posts
Posted September 24, 2014 - 08:52 PM
Welcome to GTTalk !
#4 gamefarmone OFFLINE
gamefarmone
  • 2 Thanks
  • 8 posts
Posted September 24, 2014 - 09:12 PM
Thanks for the reply, Ben.
  I was hoping that the seal material was a type that was supposed to be in there....
  I'm old enough to remember tamping oakum in old cast sewer pipes, and then pouring hot lead over the joints with my Dad, and this stuff looked an oil soaked version of the same .
  I think that oakum isn't too hard to come by even today, so tomorrow I'll start the search.
  I'm in southern WV, not too far from Beckley. After seeing your site, I realized that I talked to you the other day about a FM magneto for the old Wis. that came attached to the Page.
  I'll no doubt be in touch with you again, as Nothing in the old magneto is usable except the bottom gear.  Everything electrical, including the distributor shaft, is seized up SOLID with corrosion.
  Don't think I've seen anything that full of corrosion since I quit fooling around with salt water marine engines.
        Again, thanks,
        gamefarmone
#5 Alc ONLINE
  • 7,357 Thanks
  • 7,638 posts
Posted September 25, 2014 - 05:38 AM
Welcome to GTTalk !  Here's a brand name I remember the mechanics used at the power plant for rope seals , packing material . Good luck with your Page and please post some pictures , Al
http://www.garlock.c...ression-packing
#6 TomLGT195 OFFLINE
TomLGT195
  • 4,101 Thanks
  • 2,930 posts
Posted September 25, 2014 - 06:43 PM
:welcometogttalk:
#7 Gabriel OFFLINE
Gabriel
  • 1,449 Thanks
  • 1,863 posts
Posted November 01, 2014 - 10:25 PM
WELCOME to GTTalk!
