Electric PTO fix
11 replies to this topic
#1 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 15, 2011 - 08:01 PM
I have a 214 w/K321 with an electric PTO that needs to be rewired. I got it off but have no idea how to get it apart. Anyone know if there things can be taken apart without breaking them? At the cost to replace I might just tighten it down to engage. I am only using this tractor for snowplowing now and tilling in the spring. Thanks.
Adam
  • 14,730 Thanks
  • 15,470 posts
Posted February 15, 2011 - 08:30 PM
Is the windings bad, or the wires going into the clutch?
#3 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 15, 2011 - 09:11 PM
The wires, one is totally off and the other is getting close.
  • 14,730 Thanks
  • 15,470 posts
Posted February 15, 2011 - 09:17 PM
can you take a picture of it, I want to made sure I know which one you have. Some can be taken apart, some are sealed. They can also be repaired, but it takes a lot of care.
#5 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 15, 2011 - 09:23 PM
I was told they just pry apart originally...that did not work. Found out that person assumed it was the same as their 110 electric pto. I don't think I hurt it but...Theses are the only pics I have. I just put it back on, had to use the tractor for snowplowing. Thanks.
#6 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 15, 2011 - 09:33 PM
found this on ebay, you might want to watch this.
JOHN DEERE 214 LAWN & GARDEN TRACTOR PTO CLUTCH DRIVE - eBay (item 110649031309 end time Feb-20-11 15:40:27 PST)
  • middleageddeere said thank you
#7 olcowhand OFFLINE
  • 40,390 Thanks
  • 31,181 posts
Posted February 15, 2011 - 09:35 PM
I have repaired them broken off like that, but it is tedious & tricky. You have to dig around the broken off wire down in that hold to expose enough of it to solder the wire back onto it. Once you have a good soldered repair, then some epoxy glue to fill around the repair & insulate the connection from the metal casing. More than likely the other side where the coil lies will be encased in some sort of sealant, so repairing this connection through this little hole is about your only option, short of a used clutch or new clutch, which is expensive!!!!!!
#8 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 15, 2011 - 09:42 PM
Daniel, I've done the same thing. I used a die grinder to enlarge the hole some.
#9 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Ug...I was afraid of that. Thanks guys.
#10 olcowhand OFFLINE
  • 40,390 Thanks
  • 31,181 posts
Posted February 15, 2011 - 10:04 PM
It's tedious, but if done well, it will last a long long time. The last one I did was for my FIL when he owned the Allis 416 that I used to have. Must have been 12yrs ago that I repaired it. My BIL, member meangreen has the Allis now & the clutch is still working great to this day!
#11 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 17, 2011 - 05:55 AM
Wow, I figured you meant it was a temporary fix. That is awesome.
#12 olcowhand OFFLINE
  • 40,390 Thanks
  • 31,181 posts
Posted February 17, 2011 - 10:17 AM
When I soldered my wire back on, first I did take and cut a thin piece if a tin can & made a tiny tube out of it to slide over the overlapped broken ends before soldering. This gives the joint a lot more strength. If there is enough room, you could cut off an end to a small electrical squeeze connector & use that instead. It doesn't have to be crimped at all, just slid over the overlapped ends, as it just gives the solder a solid home. If you attempted to crimp it, you could break the wire off again.
