Trim Cylinder Lift For Craftsman
12 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 24, 2014 - 03:24 PM
Little lift I made for the Craftsman GT5000 from a trim pump off a boat.
  • MH81, Alc, KennyP and 1 other said thanks
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted September 25, 2014 - 08:15 AM
Looks very capable. Is it hydraulic?
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 25, 2014 - 08:21 AM
Yes..Its electric(12v) over hydraulic...real simple setup..trim pump a cylinders and lines all from an old boat..I just added a 3way switch.
 I will lift around 350lbs+ and has great down pressure(easily lift the rear of the tractor and rider)
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 25, 2014 - 08:22 AM
I just adapted the cylinders to the old manual lift..
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted September 25, 2014 - 08:26 AM
You may need to design a float system for that. Plows, cultivators, back blades, etc all have situations where they work better with float.
  • Auburn David said thank you
#6 KennyP ONLINE
  • 40,861 Thanks
  • 47,088 posts
Posted September 25, 2014 - 08:55 AM
I have a set of those. I was worried about bending the shafts on them.
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 25, 2014 - 09:00 AM
Not sure how you could do that with this setup..I have a row plow and a homemade box blade I use with this setup.
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 25, 2014 - 09:02 AM
Had this setup for a few years now..I dont think you will bend the shafts on them..lots of pressure holding a boat engine in place as it is pushing a couple of thousand lbs through the water..they are pretty tough.
#9 MH81 OFFLINE
  • 29,978 Thanks
Posted September 25, 2014 - 09:07 AM
Is there any way you can loop the hydraulic hoses (in to out)? That would do it.
#10 HDWildBill OFFLINE
  • 8,984 Thanks
Posted September 25, 2014 - 09:39 AM
That is a pretty neat setup.  I used a wench on mine to lift, but there is no down pressure which would be nice at times.
#11 Alc ONLINE
  • 7,223 Thanks
  • 7,578 posts
Posted September 26, 2014 - 05:43 AM
  Kenny wouldn't that be sweet to have those mounted on your mid mount grader blade to use on the side to side tilt ? Then 2 more for the angle !
#12 KennyP ONLINE
  • 40,861 Thanks
  • 47,088 posts
Posted September 26, 2014 - 05:59 AM
I have thought about it, Al!
#13 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 27, 2014 - 08:47 AM
I am looking for a electric lift for my 2001 white gt 2150 if any one knows ware I might be able to find one i would like to add a few atachments but it seems that the hitch is the first thing I will need8c6e6fb3ecea9ea7d7a01a245e5e1b88.jpg
