Running Carlisle 25X8-12 All Trails On Jacobsen Chief 1000
jacobsen chief tire size
4 replies to this topic
#1 clay033 OFFLINE
clay033
  • 1 posts
Posted September 23, 2014 - 07:25 PM
Hi All, I am reviewing replacement tire options for my 1966 Jacobsen Chief 1000. I will be replacing the original 23x8.50-12 Goodyears on the rear and 16x6.50-8 on the front. I mow with the 42 inch cast aluminum deck and would like to increase the mowing height which has me considering replacing the 23x8.5-12 Goodyears with  25x8.0-12 Carlisle All Trails. I would also increase the front tires diameter by 2 inches to have the deck level and gain a full added inch of mowing height. I was wondering if any members have gone through the process of converting over to the ATV tires and possibly a larger diameter tire on the early Jacobsens as I am considering? Thank you.
Regards,
Clay033
  • 14,889 Thanks
  • 15,514 posts
Posted September 23, 2014 - 07:27 PM
Clay, Welcome to GTtalk. Someone who knows about those tires will be along shortly to answer your questions.
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted September 24, 2014 - 05:48 AM
Those All Trials are a fantastic tire. As long as you have the clearance they will be a good choice traction wise. I think Carlisle has charts on their site that will give you the overall height and width of the tire. You might want to check this because it is usually a bit different than the nominal size.
#4 KennyP ONLINE
  • 40,925 Thanks
  • 47,117 posts
Posted September 24, 2014 - 06:06 AM
:wave: Welcome to the forum!  I put 26X12-12's on a Craftsman GTV. Had to raise the fender pan an inch for them to clear, though. I would think the Jake would be easy to put the taller tires on.
#5 TomLGT195 OFFLINE
TomLGT195
  • 4,051 Thanks
  • 2,900 posts
Posted October 07, 2014 - 06:06 PM
:welcometogttalk:  Tom
