* * * - - 6 votes
Tractor Number 15 , Will Be Cat Yellow With Tracks
408 replies to this topic
#301 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted May 28, 2015 - 06:21 PM
Thanks,
    I finished the 3rd haywagon today and tomorrow I will hitch them up for a picture. Tomorrow I will finally bring the round fender trailer inside the workshop to install the old fashioned spring seat.
  • bgkid2966 said thank you
#302 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted May 29, 2015 - 04:25 PM
First pics of the 3 finished wagons. Nothing fancy, but fun.
  • bgkid2966 and Gabriel have said thanks
#303 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted May 30, 2015 - 12:01 PM
Looks great!! :thumbs:  :thumbs:
Geno
  • Don Campbell said thank you
#304 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted May 30, 2015 - 04:32 PM
Thanks ,
    Todays pics show the round fender sulky finally done.
#305 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted May 31, 2015 - 06:13 PM
Today I decided to build a storage box and a grab handle for the round fender sulky. My wife seems real excited to ride on it , :smilewink: :smilewink: :smilewink: :smilewink: :smilewink: :smilewink: :smilewink: :smilewink:
#306 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted June 01, 2015 - 03:03 PM
The Don Campbell John Deere Train pulled out of the station on time !!! It pulled and cornered very well around my yard. :wave: :wave: :thumbs: :thumbs: :D :D :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana:
  Deb posted a You-Tube video of it in action at Don Campbell Models #194.
  • Gabriel said thank you
#307 BTS ONLINE
BTS
    Make Stuff Up
  • 4,634 Thanks
  • 2,609 posts
Posted June 01, 2015 - 10:31 PM
Don't rear end yourself!  :poke:   :smilewink:  :D
Looks good :thumbs:
#308 BTS ONLINE
BTS
    Make Stuff Up
  • 4,634 Thanks
  • 2,609 posts
Posted June 01, 2015 - 10:35 PM
I'll give you $20 if you can back (in a straight line) 20ft with all of those hooked up! :bigrofl:
#309 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted June 09, 2015 - 11:56 AM
Ha, ha,ha,
   My Cub Cadet runs perfect sometimes and then just quits for no reason. Then sometimes it will not start at all. I decided to check the contacts on the coil. Sure enough they were rusted very bad. After cleaning and reassembly it fired right up and runs perfect. We'll see if it quits again or not. Sounds like this could have been the problem. I also installed new front lights and they look much nicer. I love driving this little tractor , it goes over 15 mph top speed :dancingbanana:
#310 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted June 12, 2015 - 07:54 AM
Yesterday I repaired the old wore out steering linkage . It works like new now. Also I took some expanded metal and made a new lower dash panel. That looks much nicer. Next I will pull in the grader.
#311 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted June 14, 2015 - 06:48 AM
I fired up 10 of my little garden tractors yesterday and then I pulled the 110 , the 455 and the grader inside . I built more braces for the rear fenders for the grader and got them welded and painted. Next I will turn the grader around and work on the front axle. It steers very hard and I will see if I can tweak it a bit.
#312 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted June 16, 2015 - 05:26 PM
Todays pics show the new longer steering arms to help with more leverage for steering the grader , also I built three extensions levers for the small dia. steering wheel to help with the manual steering of the grader. I tested it out and it works much better now .
#313 BTS ONLINE
BTS
    Make Stuff Up
  • 4,634 Thanks
  • 2,609 posts
Posted June 16, 2015 - 08:24 PM
All of your projects are looking great!
One of these days your going to be finished with the smaller repairs and you will need to do another compete rebuild on a new project! :poke:
#314 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted July 01, 2015 - 11:51 AM
I am enjoying the small repairs, ha,ha.   I have no room for more projects, ha,ha.
 Todays project I am building rear wheely bars for my grandsons Hot Rod Tractor. More than once I thought the front was going over backwards , ha,ha. This will solve that problem, ha,ha.
#315 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted July 02, 2015 - 02:46 PM
Got the wheely bars built and painted. Should do the job. Now I pushed the Bolens frame steer in the shop. This never had a switch and several wires were missing. I just started it at the battery. Now I need to try to wire it to the new three post switch. It has a Acc, Ign, Batt, and a ground. So far not having much luck. Several extra wires ??
