* * * - - 6 votes
Tractor Number 15 , Will Be Cat Yellow With Tracks
408 replies to this topic
#151 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 03, 2014 - 11:43 AM
After I built the Steiner/Deere project I just had to build a silage blade for it . I actually used the original Steiner blade but rebuilt the mounting brackets , built the top spill guard and built bolt on extensions for eash end.
  • superspeedex said thank you
#152 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 04, 2014 - 03:27 PM
Todays handbuilt cab project shows me tweaking the paint with some wide stripes. It is slowly looking better but still a home made cab. I still have more tweaking to do.
  • superspeedex and Gabriel have said thanks
#153 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 05, 2014 - 05:27 PM
First test drive outside with new cab . I pinstriped the wide yellow stripes with narrow black stripes. Deb is downloading a new you-tube video now of me driving the tractor with the new cab for the first time. I am pleased with the new cab for a home made cab.
   Next week i will start the next cab for the jd 455 aws tractor. My goal will be not to make a square box looking cab for it  but some nice curves in the front window , rear corners and a curved low profile roof line.
  • Cublover, superspeedex and Gabriel have said thanks
#154 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,259 Thanks
  • 2,457 posts
Posted December 05, 2014 - 11:52 PM
WOW, that looks great, I like the tractor with the cab better then without :thumbs: :worshippy1: :worshippy1: :worshippy1: :worshippy1: :worshippy1:
When are you going to build me a cab :poke:
#155 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 06, 2014 - 08:46 AM
Thanks ,
  I like it better too.
 Todays picture shows the new jd in the workshop for the first time. I will install the linear actuator on the snowblower this weekend.
  They delivered the new jd three weeks ago today and I have not used it yet , no snow ?
  • superspeedex and FilledTires have said thanks
#156 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,259 Thanks
  • 2,457 posts
Posted December 06, 2014 - 09:21 AM
Then I'd say it was money well spent! I'm sure the whole state appreciates you buying it :thumbs: :rolling:
#157 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted December 06, 2014 - 11:20 AM
Thats cab looks great!! thould really keep the wind off of you on those cold winter days a water heater would work perfect cause of the liquid cold diesel
#158 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 07, 2014 - 10:23 AM
I will probably only use it once with the plow and chains . The cab will help sell it someday .
  Todays pics show the Linear Acuator installed and the control switch now in the dash .  Today I will wax the snowblower and the tractor .
#159 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 08, 2014 - 08:14 AM
Todays picture shows the snowblower off the jd 430 , I modified it a couple years ago to fit on the jd 455 but only used it once . Now I will have to build new mounting brackets and modify the driveshaft to fit the taller front 30in. tires .
#160 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 09, 2014 - 08:26 AM
Today I moved the snowblower in the shop . The angle on the driveshaft is very steep so I will try a longer driveshaft and new mounting brackets to make it work.
  • FilledTires said thank you
#161 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 10, 2014 - 06:14 AM
Todays picture shows the new mounting bracket to attach the snowblower with the longer driveshaft .
 Next I will remove the old extensions and build new ones that are four inches wider on each side .
  • bgkid2966, superspeedex and FilledTires have said thanks
#162 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,259 Thanks
  • 2,457 posts
Posted December 10, 2014 - 11:58 PM
But if you don't have snow for your new snow blower, then why do you need another? :smilewink:
Looking good :thumbs:
#163 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 11, 2014 - 07:50 AM
I have four snowblowers and 12 snowblades so I probably have enough now, ha,ha.
  Todays picture shows the new wing extensions installed and painted. Now I have 59in. wide to clear the back tire width . You can see the old wings on the floor.
  • GTTinkerer, bgkid2966, superspeedex and 2 others have said thanks
#164 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,259 Thanks
  • 2,457 posts
Posted December 12, 2014 - 12:44 AM
Wow, you can have a lot of machines brake down before your out of commission  :rolling: . I broke a hydraulic line on my Kubota and now I'm out of snow moving machines  :( , that is besides my big home built 4x4 articulating high loader which is for moving lots of snow but not in tight areas :thumbs:
The snow blower looks good, bring it down here to KS next Friday, we are going to get 4 inches of snow! I bet you've never seen that much! :D
#165 Don Campbell OFFLINE
Don Campbell
  • 1,575 Thanks
  • 1,186 posts
Posted December 12, 2014 - 08:52 AM
The snow has now almost stopped completely , very strange weather.
   Todays picture shows the Ariens 2 stage snowblower I bought about three years ago. I tweaked it to fit on my jd 455 2 wheel steer tractor but only used it once. I added a hydraulic motor to rotate the chute. Now I will put it on the jd 455 all wheel steer tractor after I build a cab for it .
  • bgkid2966 and superspeedex have said thanks
