A Few Months
52 replies to this topic
#16 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 19145 Thanks
  • 11910 posts
Posted September 24, 2014 - 07:52 AM
I'm just going to ignore you now.
  • NJKen, superaben and CharlesDes have said thanks
#17 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted September 24, 2014 - 09:48 AM
I'm not real up on Bolens. What is the difference between the 850 and the 900?
Huge Difference!
Body style, tires,Paint on wheels.
The 900 came first (1964-1965)  The 850 was produced (1966-1969)
  • LilysDad said thank you
#18 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted September 24, 2014 - 10:11 AM
These machines must have looked beautiful when they were new. The metallic "cordovan" paired with the cream hoods is a good mix of colors in my opinion.
As with all the Bolens metallic paint, it lost its color on exposed parts which Is why alot of us always went for the leather brown.
#19 Bigdaddydon OFFLINE
Bigdaddydon
  • 121 Thanks
  • 253 posts
Posted September 24, 2014 - 10:13 AM
One is for the choke and on the other side it the throttle.
OK, I know the choke and throttle.  I am talking about the red handled lever on the bottom left of the tower.
It looks like it would move a sheave in and out but I can see the PTO lever below it so what does this lever control?
Is it a Hi/lo of some sort?
#20 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted September 24, 2014 - 10:14 AM
Its for Hi/Low Speeds
This feature was only used on the 800,850,853&900 Models
#21 Husky OFFLINE
Husky
  • 1510 Thanks
  • 1202 posts
Posted September 24, 2014 - 11:18 AM
Yah, my 853 has the hi/low lever on it. You push it one way and it engages the  idler against the hi gear sheave belt and pull it the other way and it engages the idler against low gear sheave belt. This is physically a 3 speed tranny using a large and small pulley sheave off the engine to get hi/low range. It works great. If you look closely in the picture you can see the the two belts off of the hi/low pulley sheave where the idler goes against.
#22 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted September 24, 2014 - 02:18 PM
Sorry for the confusion but have the other guys answered your question or may I be of further help.
#23 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted September 25, 2014 - 04:57 AM
What kind of hive setup are you running? I'm thinking of building a Warre' or Kenyan Top Bar this winter.
#24 Husky OFFLINE
Husky
  • 1510 Thanks
  • 1202 posts
Posted September 25, 2014 - 06:20 AM
He asked about the red handled lever on the lower left console tower. I included a description and a couple pictures of in my last post.  That lever does move front/back and moves the idler from the low to high belt position on that dual pulley sheave.
#25 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted September 25, 2014 - 06:38 AM
 We use just the old stand-by standard large hive super with 10 frames. We however make up our hives with 3 large supers instead of the commonly seen 2 boxes. We started this as a hobby when we got to old to make maple syrup. We started with 2 hives and are now up to four. There are a few bee keepers around here that do use the top bar setup but very few. Good luck.
#26 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted April 02, 2015 - 01:47 PM
It is coming along slowly
Edited by Deerlope, April 02, 2015 - 01:48 PM.
  • Bolens 1000 said thank you
#27 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted April 02, 2015 - 01:51 PM
Not sure if you meant to do this or not but the rims should be white if your going for an original looking tractor......
  • Deerlope said thank you
#28 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted April 02, 2015 - 05:15 PM
Ok a change at this point will be easy. I did not have a paint scheme  to guide me and they were red when I started sandblasting. Thanks B-1000. Is it pure white or kind of a cream color or what it called off white?
Edited by Deerlope, April 02, 2015 - 05:17 PM.
#29 Husky OFFLINE
Husky
  • 1510 Thanks
  • 1202 posts
Posted April 02, 2015 - 06:16 PM
WOW this thread is one that I forgot about. I've got an 800 and how cool it would be to paint it in that metallic color that Bolens 1000 mentioned. I'll have to follow this post. Your 900 is looking fantastic as usual. I can't believe how nasty that hood looks with the ripped metal where the lights were. Too bad there was not one that you could replace it with.
#30 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted April 02, 2015 - 06:38 PM
I will assure anyone that when I am done with that hood you will never know there were ever headlights there. Stay tuned for more later.
